Old 01-28-2015, 07:10 PM   #1
SalemSierra's Avatar
Gas smell inside!
We have had our TT for less than a year and this is the first I have come across this. Our furnace and water heater run on gas. The camper is plugged in at our home and we keep everything on as we go in there from time to time. I have recently smelled a dead animal smell in the camper. I pulled apart everything to find it and it is very clean. Nothing. Then it almost smelled like propane so I checked the water heater and furnace and couldn't smell it. Everything fires up and works perfectly but I can't find the source. I will try and use some leak detector tomorrow to dig deeper. Anyone have a similar accurance?
SalemSierra is offline   Reply With Quote
Old 01-28-2015, 07:28 PM   #2
Old Enough to Know Better
gasman6674's Avatar
Make sure all of your traps are full of water or antifreeze as tank can give you a funky smell.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 01-28-2015, 07:47 PM   #3
caper's Avatar
I had a propane smell in the trailer and discovered the quick release for the outside BBQ was leaking.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-29-2015, 06:27 AM   #4
arpipeliner's Avatar
My wife smells the propane if the pilot light is on in the oven and the bottle is getting toward empty. I have a couple of times too. Turn off the pilot light in oven and all is good here.
arpipeliner is offline   Reply With Quote
Old 01-29-2015, 06:48 AM   #5
Toby's Avatar
First thing I would do is shut the propane off at the bottle(s) and see if the smell goes away. Open the windows for a bit and the close it back up. If it is a propane leak then you don't want appliances firing up anyway. Hopefully the smell doesn't go away and it's something stupid like a dead mouse or the black tank venting. Just my 2 cents worth.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 01-29-2015, 07:13 AM   #6
I'm thinking it's from one of your holding tanks, maybe black tank.
Pipeman is offline   Reply With Quote
Old 01-29-2015, 07:21 AM   #7
asquared's Avatar
X2 on this. We actually found a hole in the hose going to our fridge. It had gotten pinched in the slide. Fridge kept trying to fire and couldn't because it wasn't getting propane due to leak. We were lucky not to have an explosion/fire.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-29-2015, 08:15 AM   #8
Wow! Now I have to check on that....we have noticed the smell when our propane tanks are low, it's usually my first hint. But we also think we go through propane insanely fast...maybe we better look for some leaks!
kkhslh is offline   Reply With Quote
Old 01-29-2015, 11:32 AM   #9
If it was a propane leak your propane detector would be going off. You do have a functioning detector, don't you?
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 01-29-2015, 11:56 AM   #10
caper's Avatar
I had a functional detector and when the valve was leaking it did not set the detector off. The detector is in the bedroom area and the propane smell was in the kitchen area near the door.
Terry and Janet
2007 Ford F150
gas
