Old 04-25-2016, 09:21 PM   #11
StoneyG's Avatar
Originally Posted by B and B View Post
Hello,
Is the secondary regulator painted red? Has 10 psi out?
The original was red and the one I have know is red. We tried a different, not red one on the first replacement. I don't know the PSI.
StoneyG is offline   Reply With Quote
Old 04-25-2016, 09:23 PM   #12
StoneyG's Avatar
Just a thought, swap the pig tails in case the shut off valve is one of the pig tails is bad.
Thanks, another idea to try. Forums are better than dealers for solving problems.
Old 04-26-2016, 10:37 AM   #13
StoneyG's Avatar
Hello,
It is red and is marked 30PSI
Old 04-26-2016, 10:49 AM   #14
CANADA FROG RALLY 2017
B and B's Avatar
That should work fine, is it cold out when it stops working? Wondering if the regulator is freezing up. I have seen many heaters and propane powered generators free up in our Canadian winter (think top a mountain in Banff doing World Cup Skiing temp was -25 C with Human Windchill at -40 C)
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 04-26-2016, 11:15 AM   #15
StoneyG's Avatar
Originally Posted by Learjet View Post
There is legal requirement to run the High pressure propane thru a secondary regulator to go to the other side of the trailer on a 5th wheel. Common setup on 5th wheels.
To answer the OP, had the same issue...changed the pigtail, red regulator and then found it was a bad check valve on the switch over regulator. Right where the hose attaches from the driver side bottle to the change over regulator there is a check valve.
To let you know, I looked this morning and didn't see what I could identify as a check valve. I noted the brand and went to Fairview's web site and found that the check valves look just like copper/brass threaded fittings but are also the check valves. I called the factory to see if it would be alright to swap those fittings to test them and I was told not to do that, but the tech did tell me that it was likely that the problem was with their regulator either the check valves or regulator itself. He wants a dealer to check it before replacing it, it could also be a crimped line. There is a testing procedure to got through and also for safety reasons they can't suggest other than a dealer work with the propane lines/fittings. I'll take it to a trusted dealer.
Old 04-26-2016, 11:34 AM   #16
B and B's Avatar
Good Move.
B and B
Old 04-26-2016, 12:06 PM   #17
StoneyG's Avatar
I'd love to back to Banff, but not in the winter.
We started having problems in Virginia last winter in 15 degree weather. But we've had the same problem while we're in Florida in the mid to high 80's.
Old 04-26-2016, 12:29 PM   #18
Witch Doctor's Avatar
I would bet that the pigtail went bad, if I'm not mistaken there is a valve inside them. I had to replace one already, then everything worked again. Key word here MISTAKEN. I have been known to be proven wrong.... But they are cheap...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 04-26-2016, 12:31 PM   #19
StoneyG's Avatar
Thanks, I'll get that checked too.
Old 04-26-2016, 12:47 PM   #20
Occasional campers
Changeover no workee
Just an additional comment that with our TT, I have never gotten the automatic changeover to work properly. Almost always, the first tank will empty and suddenly nothing works; the valve is set for automatic changeover, but the second tank is full and nothing happens. I have to physically switch tanks in order to get things to work. At least one campground operator, when I was buying LP and mentioned this, said that in his experience the automatic changeover valves almost never worked.
Does anyone know of an automatic changeover valve that is actually reliable and does what it's supposed to do?
Ray and Ann is offline   Reply With Quote
gas, tank
