Old 04-26-2016, 11:51 AM   #21
Pigtail
Checking the pigtail is a good suggestion, I've had two of them go bad both in cold weather.
traindrv is offline   Reply With Quote
Old 04-26-2016, 12:02 PM   #22
Stormrider151's Avatar
I had both pigtails go bad after putting gauges on the tanks (bad idea). Replaced both and that solved the problem. One other thing to check for is a crimped line somewhere.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-26-2016, 12:03 PM   #23
Originally Posted by Flybob View Post
You may have activated the flow control safety valve. If the gas lines are empty and you turn on a tank quickly, the safety valve activates and shuts off the gas. Shut the valve Disconnect the propane line and let it sit for a few minutes. Reconnect then slowly open the valve ( especially the initial 1/4 turn) and allow a slow flow of propane to fill and pressurize the line.
StoneyG, Flybob has the identification to your problem (or at least, this is what happened with mine)
What Flybob has described above is what solved my issue as the flow control safety valve in the pigtail is what was activating with my road side tank. I now solve it a little quicker:
- first extinguish all sources of spark/flame
- wear gloves / eye protection
- close off the tank valve
- loosen off the pigtail connection (large green knob in my case)
- open tank valve (no propane should flow because of the tanks own built-in safety valve)
- while tank is open, slowly screw in large green knob until you hear a quick spurt of propane (PFFFST)
- stop immediately screwing in green knob
- close tank valve
- loosen green knob 1/4 turn
- open tank valve SLOWLY about 1/2 turn
- tighten green knob slowly until PFFFST is heard again, then completely tighten green valve
- slowly open tank valve another 1/2 turn, then open fully all the way
It's at this point I go inside to my farthest propane appliance from the tank (stove) and light a burner to test full flow of propane. *Usually* this process will work and I'm off and cooking with gas. I will only run off that tank until it's low, then manually switch the auto-switchover valve to the curbside tank.
Just a solution that works for me. Please be sure to extinguish all sources of ignition before trying this. Although there is only a very small PFFFST of propane, there is still a chance....
J.
jcrayford is offline   Reply With Quote
Old 04-26-2016, 12:24 PM   #24
BBBlue's Avatar
Agree with B and B on the bad pigtail.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2015 Days camping-185
2016 Days camping-238
BBBlue is offline   Reply With Quote
Old 04-26-2016, 02:49 PM   #25
I have the same issue. Changed out the auto regulator and red regulator, no help. Noticed that the pigtail on the road side did not have a check valve but the other side did. Also the 8' hose from the red regulator to the auto regulator has a check valve in it at the auto regulator end. Would have made more sense if the check valves were attached to the auto regulator and not the hoses. I sent my 5er back to the service dept for them to fix.
timerie is offline   Reply With Quote
Old 04-26-2016, 03:27 PM   #26
Iwannacamp's Avatar
Originally Posted by Ray and Ann View Post
Just an additional comment that with our TT, I have never gotten the automatic changeover to work properly. Almost always, the first tank will empty and suddenly nothing works; the valve is set for automatic changeover, but the second tank is full and nothing happens. I have to physically switch tanks in order to get things to work. At least one campground operator, when I was buying LP and mentioned this, said that in his experience the automatic changeover valves almost never worked.
Does anyone know of an automatic changeover valve that is actually reliable and does what it's supposed to do?
Buy one that Fisher on it. Problem solved.
On mine I had to turn on and walk away for like 30 minutes. It will finds its happy place. The changeover takes forever when you are waiting.
I will never admit this...when I think about it I would turn on the bottles way ahead of time. Worked every time for me.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 04-26-2016, 08:53 PM   #27
rracer5's Avatar
Bad pigtail. Happened on my previous TT. I replaced the pigtail and all was good. seems that one of the inner "layers" of the rubber hose has been breached. When the void between layers fills with propane, it plugs up the flow. That's why it works "sometimes".....it may be just a small breach and takes awhile to balloon the inner layer to the point of blocking the flow.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-27-2016, 07:19 AM   #28
StoneyG's Avatar
When we first got the RV I kept both bottles open and they switched over without any problem. I just got in the habit of checking for green or red on the regulator once a week. I'd love to get back to that.
BTW, our regulator is a Fisher.
StoneyG is offline   Reply With Quote
Old 06-22-2016, 03:00 PM   #29
j Crayford, when you say "extinguish aii sources of ignition before trying this " do you mean extinguish all pilot lites? Sometimes we get enough propane to run fridge and stove top but other times, it seems that only the freezer works, not the fridge and very minimal propane to stove top, with great difficulty even lighting burners.
2 Old Geezers
2 Labradorables
2015 Dodge Ram 1500-Rambo
2015 Roo 21BD-L'ABode
lablover is offline   Reply With Quote
Old 06-22-2016, 03:32 PM   #30
Left Coast
Pig tail....
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
gas, tank
