Old 07-22-2016, 10:50 AM   #1
GR630 LP regulator is leaking. Trying to find a replacement.
Added a freshly filled tank to the street side of my 5th wheel, the Gas Flow GR-630 regulator started leaking out the weep hole right away.
From what I've looked up, i need to replace it. Working out of town and tried 3 rv shops.
The all offer the Marshall Excelsior replacements but have provided me with different part numbers. Would the replacement for the GR-630 be the Marshall Excelsior MEGR-610B or the MEGR-130-30 ?
I believe it would be the MEGR-130-30 for 10 PSI? The website says the 610B is discontinued.
Thank you for your time.
Leichardti is offline   Reply With Quote
Old 07-22-2016, 11:36 AM   #2
Old Enough to Know Better
gasman6674's Avatar
A 10 psi would work in a pinch, also if you could find an adjustable regulator rego 597 or fisher 67 series in the 3-25 range they would work better.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is online now   Reply With Quote
leak, replacement
