Old 04-16-2014, 03:57 AM   #1
Heat Temperature in Bathroom
I have a 2014 Flagstaff V-Lite 30WIKSS. The temperature from most of the registers is around 90 degrees; however, the temperature from the register in the bathroom is around 65 degrees. I have checked and the hose is attached to the back of the register. Where else should I check? Is it connected to the register in the bedroom (which is 90 degrees), or is it a separate hose from the furnace?
hsorrells is offline   Reply With Quote
Old 04-16-2014, 05:39 AM   #2
Weezer's Avatar
We owned the same model last year and had the same issue (wouldn't call it a problem). With the front bathroom the duct for it is at the end of the duct run...less air movement and greater temp drop. We just used a small ceramic heater in there.
Question for others: I can't seem to spot any duct insulation on the metal ducting in our current or former RV, interior or exterior. Is the ducting seriously not insulated?
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 04-16-2014, 06:47 AM   #3
From looking at our Flagstaff 8528RKWS, none of the duct work is insulated. I think that's how they can make the "heated underbelly" claim.
Old 04-17-2014, 02:54 AM   #4
Grn_Mtns's Avatar
2014 3025 windjammer . Same thing cool air in bathroom duct. Will not hear up. Probably too far from heater. 32 degrees tonite in VA on our way back to VT. Rest of unit is toasty and highly recommend FR for construction and easy towing on this TT.
2014 3025 Windjammer/260watts solar
Grn_Mtns is offline   Reply With Quote
Old 04-17-2014, 05:22 AM   #5
mark0224's Avatar
Close other vents partially causing more air flow to go to the easiest restriction. In the v lite 30 wrls there is no heat duct in the bathroom but the bedrooms vent is the long run. The rest of the trailer is over warm.
mark0224 is online now   Reply With Quote
