Heat Temperature in Bathroom
I have a 2014 Flagstaff V-Lite 30WIKSS. The temperature from most of the registers is around 90 degrees; however, the temperature from the register in the bathroom is around 65 degrees. I have checked and the hose is attached to the back of the register. Where else should I check? Is it connected to the register in the bedroom (which is 90 degrees), or is it a separate hose from the furnace?
Thanks,
