Old 01-08-2015, 11:43 AM   #21
Witch Doctor's Avatar
Sgtyates, On page 9 of suburban is a wiring diagram in the library, jumper the red and white to see if it will come on. I don't trust any of these garbage stats. It can't be the sail switch, could be the limit. I think they are click-on's like Carrier used. I do not know of any on and off switch for the furnace, only if it controlled the blower motor to circulate air with out the furnace on. You might be pulling that cover off, Good luck, hope you got your multimeter with you. Did you buy your unit new or used? I doubt if your motor went out filling with propane at the same time. What do you have a motor home? Obviously there is something stopping 12v to that motor. Let us know what you find..Thanks
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-08-2015, 11:49 AM   #22
We got it used Yes Motorhome 2002 Georgetown with 100 lbs on board tank I had filled at local hardware store after they filled he said "We only get about two or three of these a year " and me thinking good place to go becouse snowbird town I live in
Sgtyates is offline   Reply With Quote
Old 01-08-2015, 12:52 PM   #23
KyDan's Avatar
You need to check if voltage is getting to the fan motor.
Some here have reported fan motor had a "dead spot" on the rotor and
if they spun it with a screwdriver to a new spot it would run.
Maybe it's time to call a repair person. These furnaces aren't all that hard
to trouble shoot but if you don't have expertise maybe it's time to make the call.
Sounds to me like you're rapidly approaching the point of pulling the unit
out. After a couple times I can get mine out in under 10 minutes but they
are all different in how/where they are installed.
Peace!
Dan & Rita D
Old 01-08-2015, 01:01 PM   #24
Yeah!!!! I'm holding the towel in my hand just about ready to toss it in I really dont want to pull thos thing out but I know that when I get Campingworld and they hand me a bill for 300 buck for tripped breaker under driver seat in the zipper that is covered by the sticker that talks about how to pull out the canopy
Old 01-08-2015, 03:13 PM   #25
Sometimes when you run out of propane, a bit of trash is sucked up and will be found in the propane orphis. As a last resort, clean the orphis with a small wire.
saltyman is offline   Reply With Quote
Old 01-08-2015, 03:22 PM   #26
Saltyman what would that have to do with the eletric fan motor does it have a relay that will trigger to also shut off electronic parts too
Old 01-09-2015, 07:46 AM   #27
KyDan's Avatar
No.
Your lack of fan motor sounds like fuse or bad relay or stuck/defective motor etc.... The fan should be the first thing that "happens" when the
t-stat calls for heat. If you hear a click and then nothing it sounds like
the relay is closing but for reason's listed earlier the fan does not start.
That's assuming the click is coming from the furnace....
Peace!
Dan & Rita D
Old 01-09-2015, 08:24 AM   #28
The click is coming from the furnace becouse I can reach the on/off swich on the unit and will click when I turn it off then back on I cant find a fuse in that location .
Cant do anything but pull unit ,
Do you know if there is a fuse panal somewhere that I'm not finding
1) Bedroom
2) understars with house batts.
"But sure thats for cab"
Old 01-09-2015, 08:56 AM   #29
KyDan's Avatar
I don't know about other fuses but there will be a power lead going to the
furnace. It is probably heavy 2 conductor wire that is probably black and
white. It will probably be wire nutted very near the furnace. The connection might be inside the furnace or just outside the furnace. I would look for those wires and check for 12v across them with a good meter or even a 12v test light. There will also be 2 wires going there from the T-stat.
You want the power wires and you need to be sure they are in fact feeding 12v to the furnace. A click coming from inside the furnace makes me lean more towards a blown fuse inside the furnace or a bad relay inside the furnace or a bad blower motor (motor has a dead spot and might work if spun to a new stopping point).
Good Luck!
Peace!
Dan & Rita D
Old 01-09-2015, 09:00 AM   #30
Yeah tryed all that got power spun motor just clueless
I did home A/C for 20years
But never did gas or RV being in Florida don't need to much heat here
Old 01-09-2015, 09:16 AM   #31
KyDan's Avatar
Time to pull the furnace.
There are YouTube video's of various furnace trouble shooting tips.
Some pretty helpful. Look for RV furnace repair....
If you get to the place where it's a relay soldered to the control board you can get a dinosaur replacement board for about a hundred bucks that is a perfect fit replacement and dino boards are highly rated as better than new by many of us in the RV nation!
Peace!
Dan & Rita D
Old 01-09-2015, 09:21 AM   #32
Ok thanks gess I'm pulling the sleves up and getting the knuckles bloody and pull the furnace I will hit you up if got ?
Thanks for your help
heater, propane
