Old 01-06-2015, 08:20 PM   #1
Heater blower will not come on worked before I ran out of propane
I ran out of Propane came back to park now nothing will work on heat
I dont understand what has happend it clicks like it is calling for heat but nothing is there a fuse in the blower motor I cant see not sure if I want to put furnace out or get surviced
Sgtyates is offline   Reply With Quote
Old 01-06-2015, 08:27 PM   #2
Professional Texan
TexasBob's Avatar
Check your stove and see if you can light it. If you cant, close the valve on the top of your propane tank and open it very slow. Then try again.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 01-06-2015, 08:29 PM   #3
Stove works great!
Old 01-06-2015, 08:31 PM   #4
Professional Texan
TexasBob's Avatar
Stove works great!
Good, that means you have propane. Did you try your heater again?
Texas Bob
Old 01-06-2015, 08:34 PM   #5
Heater was working great till we ran out of propane during the night and the next day I took Coach down and got Her filled up next cold spell tryed to turn on the heat and now the heat will not come on not even the blower motor will come on
Old 01-06-2015, 08:39 PM   #6
Professional Texan
TexasBob's Avatar
That is about all I can suggest from long distance except checking DC fuses and reassuring yourself that the thermostat is properly on and set.
Wish I could be more help. Maybe someone else on the board has some ideas.
Texas Bob
Old 01-06-2015, 08:43 PM   #7
looked at fuses in bedroom and under stairs and t-stat in right place thanks for your help and if you might talk to someone on here that might know something about it have them give me a shout
Old 01-06-2015, 08:46 PM   #8
Flybob's Avatar
Does the fan come on when it calls for heat? if it ran out of propane and you removed the tank to fill, you have some air in the lines, It will take a while to light. There is a safety switch that shuts off gas if the heater does not light after a short period of time. You will hear the piezo lighter click, but until gas reaches the heater and it lights, the heater will shut down.,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-06-2015, 09:08 PM   #9
The fan will not come on and this is an onboard 100lb tank
Old 01-06-2015, 09:09 PM   #10
iluvlcy's Avatar
If we run out if propane we have to turn furnace off then on again. Guess it needs to reset.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 01-06-2015, 09:11 PM   #11
Iluvlcy where do you do that ?
Old 01-06-2015, 09:12 PM   #12
wmtire's Avatar
If you have a Suburban furnace, it works as Flybob stated. It attempts 3 times to light, and then goes into lockout mode if unsuccessful. You have to turn the furnace completely off at the thermostat, then back on to reset the lockout.
If there was air in the lines, it may take several attempts to purge it out...and thus your furnace may go into lockout even more than once.
Turn it completely off at the thermostat and then back on, to reset the lockout.
This may help:
Forest River Forums - Downloads - Furnace - Suburban furnace troubleshooting
EDIT: I see where iluvlcy was already stating the same thing as I was typing and getting the links.
2011 Flagstaff 831 RLBSS
Old 01-06-2015, 09:13 PM   #13
iluvlcy's Avatar
At the thermostat, happened to us this weekend. Turned on new tank after running out and furnace did not come on til we turned off at thermostat.
Pam & Don
2011 Rockwood 2304s
Old 01-06-2015, 09:35 PM   #14
Tryed that still no fan motor and the link will not let me go there
Old 01-06-2015, 09:53 PM   #15
Flybob's Avatar
You can try pulling fuse for furnace wait a min and reinstall.
TST Tire Monitors
2 100W solar panels
Old 01-07-2015, 09:34 PM   #16
This same thing happened to me last year and it was fixed by turning the furnace off for a min then back on again.
DuckCamper is offline   Reply With Quote
Old 01-08-2015, 08:16 AM   #17
mcmartinez's Avatar
The heater will not come on unless your fan kicks in first. Is a safety thing. You need to figure out why the fan is not coming on, fuse or bad fan motor. If you can get to the fan see if power is getting to it. If it is then is probably a blown fan motor. If not then is a power source issue, blown fuses or ???.
Mario Martinez
2703WS Rockwood Super Lite (6,400 Dry weight)
Tow Vehicle - 2016 Ford F150 Lariat Platinum Limited
3.5L EcoBoost (12,200 Towing Capacity)
mcmartinez is offline   Reply With Quote
Old 01-08-2015, 08:49 AM   #18
sail2liv's Avatar
Sail switch? have to remove inside panel to access.....would check that if no fan before going plundering.....no sure if you have one....not sure if any heating item is do it yourself....some things are best left to the pros....next time operate all you gas equipment when you fill, good luck...
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 01-08-2015, 09:49 AM   #19
Witch Doctor's Avatar
Go the forum library. There should be stuff posted there. It sounds like an electrical problem. If you have done as said with the stat and wait for a couple of minutes to let it reset the blower has to start before it can lock out. Check your stat see if the fan switch will bring on the ac fan motor. If it will then the power to the stat is working. If not you have a blown fuse. You didn't mention what unit you have, so can't help with fuses. What thermostat do you have?
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-08-2015, 10:21 AM   #20
Duo-therm the ac works fine
The roof blowers come on for both,if I have the covers off the t-stats and push down to call for heat where the heat strips would start the roof blowers fire off BUT I DONT HAVE HEAT STRIPS "DAMN" I
I have looked at every fuse I can think of I found the on off switch on the furnace and flipped it it just clicked so I now its getting power but to work on it any further I have to pull the whole unit out
Installed residential A-C. for over 20yrs but this is a new beast I know nothing about
"Stumped"
heater, propane
