Old 03-21-2014, 09:39 PM   #1
Mountain Goddess
Help - on the road and no propane
Hello, I'm brand new to the forum and on my maiden voyage with my brand new A-frame hardside with the BBQ outside and stove inside. All else working great, but I'm not getting any propane to either the BBQ or inside stove. Yes, the tanks are heavy and full, turned on and I've flipped the switch both ways to try both tanks (and turned both on to be sure.) I'm far from restaurants so was counting on cooking tonight and tomorrow. Any help would be MUCH appreciated. Thank you in advance!
Annabanana is offline   Reply With Quote
Old 03-21-2014, 09:45 PM   #2
ironj's Avatar
make sure you open the valves on the tank SLOWLY....or it may shut off thinking there is a leak....also, you may need to purge the lines....run the stove inside till it starts or you can smell propane..make sure there is a flame next to burner so you know when it starts...
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 03-21-2014, 09:50 PM   #3
SKnight's Avatar
Close both tanks, make sure that the system items are all off, stove, grill, etc. disconnect both lines then reconnect them. Once reconnected slowly open the valve on the tank the valve is towards. Once on turn the other tank on. Then, go check the stove. Hopefully you have gas flowing.
LPG valves have a safety built in, if the system is at zero when you turn the vales on the tank thinks there's a leak and shuts down.
Hope this helps and welcome!
Old 03-21-2014, 09:50 PM   #4
Oaklevel's Avatar
X2
Also welcome to the Forum
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-21-2014, 10:01 PM   #5
ironj's Avatar
oh yeah...and welcome to the river clan!..lol
Old 03-21-2014, 10:17 PM   #6
Mountain Goddess
thanks to all for such speedy replies. I will try all tomorrow and hopefully have a nice hot breakfast. I'm delighted to be part of such a great community. Thanks again!
Old 03-21-2014, 10:38 PM   #7
One other thing that you can try if the above does not work is to turn off all appliances, turn off the valves on the tank, remove the tank and find a hard surface like a concrete sidewalk with nothing that could poke the bottom of the tank and lift and drop the tank 3 or 4 times not to hard but hard enough to try to free up the OPD inside the tank, sometimes the shut off valve inside gets stuck and needs a forceful tap. Re connect and see if you get the gas flowing again.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 03-21-2014, 10:44 PM   #8
MI Camperz
bodzcampers's Avatar
In other words....the old bang on it till it works trick?
MI Camperz
bodzcampers is offline   Reply With Quote
Old 03-22-2014, 11:20 AM   #9
Mountain Goddess
Success! Thanks everyone, you saved the day! Enjoying a hot cup of coffee in 30 degree weather. Didn't know about that line shut off feature.
propane
