Old 05-17-2014, 09:55 AM   #11
fot3's Avatar
It jut keeps blowing pilot out and have to keep relighting, big poof when turning to to on from pilot
Sent from my SCH-i705 using Forest River Forums mobile app
fot3 is offline   Reply With Quote
Old 05-17-2014, 10:35 AM   #12
Witch Doctor's Avatar
That means that your pilot is out of adjustment, and you getting what is called delayed ignition. The gas is filling the chamber until it ignites. Make sure your pilot hood is putting a flame on the burner itself.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-17-2014, 10:39 AM   #13
fot3's Avatar
So which way do I turn the adjustment screw u think, clockwise or counter clockwise to increase flame
Old 05-17-2014, 11:01 AM   #14
I would think counter but just turn your gas valve to pilot, then light it and adjust it before you open the valve to gas. You might have bent it when installing the thermocouple to, You don't need a big flame but it has to hit the burner. If you adjust it to high you will cause a yellow tip to big that will create soot. Yellow tip no more then 1/4".
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-17-2014, 11:16 AM   #15
fot3's Avatar
We just adjusted that and seemed to work, having trouble seeing because of sun, I appreciate your help
Old 05-17-2014, 11:57 AM   #16
Check the flame tip at night, it will be easy to see, glad to help ya, have fun camping.
Coachmen M/H
Concord
2018 / 300 DSC
heater, water, water heater
