04-06-2014, 08:23 PM
Help with water heater, newbee
2002 Wildwood 30BHSS LTD, I'm pretty sure it's the SW6PR. Had it running yesterday but it keep trying to restart like the pilot was out, the reignitor was ticking like crazy, off and on. But we had hot water. This morning we get up ticking was not as loud and lite on switch was not as bright but no pilot was lit and did not have hot water. Both gas tanks are good and on, stove works. Didn't now if we have a reset in trailer that we can't find or some other issue and we just are screwed and need to call a tech out. I've tried restarting the whole process even with powering down the TT to try and reset. Any ideas?
04-07-2014, 08:19 AM
Old Enough to Know Better
Are you on shorepower or battery? Also your igniter may need to be adjusted closer to burner so control can "sense" the pilot flame. If you dont have a manual you can download one from the Suburban site or one of our excellent members will post one.
(Sorry I have an Atwood)
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
04-07-2014, 08:36 AM
You should have a reset limit outside on the water heater. See if that popped open it's behind a black rubber cover. I either assume that you are either not using electric or is your unit is propane only? The part that puzzles me more is the dimming of your switch. That could happen if you are grounding in that circuit somewhere. If you have a volt meter measure the voltage at the limit first. You might also try and pull the gas tube out and clean it and look at the gap of the ignitor, should be like 1/4" you could have blockage in the pilot tube itself. If all that is okay or if your not comfortable doing that stuff, call a service guy. In the mean time you and your better half can take a shower together and pour hot water from the stove over each other. Just to save water of course. Good luck hope you get it figured out.
Coachmen M/H
Concord
2018 / 300 DSC
04-07-2014, 11:24 AM
Yeah it's propane only, didn't see a reset behind anything in the tank near any controls
04-07-2014, 11:31 AM
Fonzie
04-07-2014, 07:29 PM
Thanks for the response, this model does not have the high limit switch. Thanks again I will check switch with my voltmeter.
Sent from my SCH-i705 using Forest River Forums mobile app
04-07-2014, 07:42 PM
It sounds like it could be lack of fuel. Did you try burning your stove for a few min to get any air out and also to confirm you have a good fuel flow?
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
04-07-2014, 07:45 PM
Yes a number of times, plenty of fuel
04-22-2014, 06:57 AM
Update, the thermocoupler was bad, had to get a tech out to look at it. Thanks for the help
05-15-2014, 08:49 PM
Little more help please, changed the thermo coupler and can only light manually, but with the wind from the beach it will not stay lit, any ideas, can I use a wind deflector or stay away from that
05-17-2014, 09:55 AM
It jut keeps blowing pilot out and have to keep relighting, big poof when turning to to on from pilot
05-17-2014, 10:35 AM
That means that your pilot is out of adjustment, and you getting what is called delayed ignition. The gas is filling the chamber until it ignites. Make sure your pilot hood is putting a flame on the burner itself.
Coachmen M/H
Concord
2018 / 300 DSC
05-17-2014, 10:39 AM
So which way do I turn the adjustment screw u think, clockwise or counter clockwise to increase flame
05-17-2014, 11:01 AM
I would think counter but just turn your gas valve to pilot, then light it and adjust it before you open the valve to gas. You might have bent it when installing the thermocouple to, You don't need a big flame but it has to hit the burner. If you adjust it to high you will cause a yellow tip to big that will create soot. Yellow tip no more then 1/4".
Coachmen M/H
Concord
2018 / 300 DSC
05-17-2014, 11:16 AM
We just adjusted that and seemed to work, having trouble seeing because of sun, I appreciate your help
05-17-2014, 11:57 AM
Check the flame tip at night, it will be easy to see, glad to help ya, have fun camping.
Coachmen M/H
Concord
2018 / 300 DSC
