Old 03-07-2014, 11:03 AM   #11
Originally Posted by HONDAMAN174 View Post
Like this?
Camco 59843 20" Pigtail Propane Hose Connectors - Acme x 1/4" Male NPT by Camco Amazon.com: Camco 59843 20" Pigtail Propane Hose Connectors - Acme x 1/4" Male NPT: Automotive
No, kinda the opposite. I have one of those fryer burners that I would like to take camping with me from time to time. My Crusader has the gas grill line quick connect in the back that allows me to use the on board propane with the grill that came with it. The fryer has the standard screw on connector like you would use to connect it directly to a propane tank. I would like to find a adapter that would screw into that and then would let me use the quick connect on the back of the 5ver.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 03-07-2014, 11:11 AM   #12
Old Enough to Know Better
gasman6674's Avatar
For example: 10 ft of 3/8 id hose will carry approx 110,000 BTU at 11"WC RV QD pressure and 1.3 million BTU at 10 psi so length, pressure and load are important.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 03-07-2014, 11:16 AM   #13
gasman6674's Avatar
Maybe maybe not depends on operating pressure of the fryer.
You would probably need this
Mr. Heater - America's Most Popular Portable Heaters
Old 03-07-2014, 12:05 PM   #14
I would only be using the burner to heat oil to make a batch of FF or fry up venison chunks.
Would something like this work Amazon.com: GrillPro 11051 Universal Fit Propane Tank Adaptor: Patio, Lawn & Garden and then reduce it to a hose connector that will fit the quick connect?
Old 03-07-2014, 12:15 PM   #15
Kaadk's Avatar
Hooking up camp chef stove to quick connect
If I understand correctly, you're looking for an adaptor to go between where you would normally hook up the tank and your 5's quick connect? And this is to allow you to use the 5's propane instead of getting it from a separate tank?
If I got that all right then, well, it doesn't work...
Between the tank and the BBQ, Fryer, Griddle, Camp stove, whatever is a regulator. Off the propane tanks on the 5er is a regulator. By the time the propane hits the quick connection, it's already regulated. Attempting to pass it through a second regulator (the one between tank hookup and whatever) is going to drop the pressure too much to be able to burn.
That's why all these adaptors that are out there now require you to remove the existing connection from your whatever if you're going to use the quick connect.
Old 03-07-2014, 12:27 PM   #16
Between the tank and the BBQ, Fryer, Griddle, Camp stove, whatever is a regulator. Off the propane tanks on the 5er is a regulator. By the time the propane hits the quick connection, it's already regulator. Attempting to pass it through a second regulator (the one between tank hookup and whatever) is going to drop the pressure too much to be able to burn.
Yes you are coorect. OK that makes sense. So I am actually over thinking it. All I really need to do is replace the hose with the regulator on the fryer with is one with no regulator. I would still need some kinda valve at the fryer to control the burner though which wouldn't be hard to do.
Old 03-07-2014, 12:46 PM   #17
Kaadk's Avatar
Ah, so your valve is at the tank connection? I guess that's why you were looking to save it. In that case maybe check to see if your dealer has a scrap RVQ or Sidekick laying around that you can get your hands on. You might be able to salvage the valve from there and it'll already be ready for the quick connect.
Edit: Another option, a quick Google search for "RV Propane Quick Connect Hose with Valve" pulled up http://www.campingworld.com/shopping...-connect/56292
Old 03-07-2014, 01:24 PM   #18
gasman6674's Avatar
Look at the spec's for your fryer if it needs 1,2 or whatever psi to burn you will not be able to hook to up to your trailers quick disconnect. I will not burn right. The reason I say this is if it came with an adjustable regulator then more than likely it is high pressure. If it came with a non adjustable regulator make sure it does not have a tag on it that says --psi or the regulator is red if so it might be high pressure. If it has a non adjustable regulator and a adjustment valve for flame height you MIGHT be ok. Read the manual it should tell you.
Good Luck
Old 03-07-2014, 02:01 PM   #19
HONDAMAN174's Avatar
RickV- are you going to be without power where you will be frying up? Reason I ask is there are electric deep fryers out there- think I bought mine for about $75. Might be an easier setup/teardown.
Just glad to get away
Old 03-07-2014, 02:39 PM   #20
Good Luck
It says 10psi on the knob so I guess I am SOL.
Yeah we have one. I just like the gas better heats the oil faster plus I will be cooking outside and if it happens to get rained on less damage to the gas one. I will probably end up going with the electric due to fact I can't run it from my quick connect.
To everyone who chimed in
