Old 03-06-2014, 09:37 PM   #1
mstell2's Avatar
Hooking up camp chef stove to quick connect
I saw camp chef sells an 8 foot hose to hook to the camper quick connect. I would like to do this with mine but I would like a longer hose. My question is how long of a hose could be used? I would like to get one 15 to 20 foot. Would that be too long?
mstell2 is offline   Reply With Quote
Old 03-06-2014, 10:06 PM   #2
davel1971's Avatar
I've never seen one that long. Guess you could couple two together.
David & Lynn
Old 03-06-2014, 10:10 PM   #3
HONDAMAN174's Avatar
Just bought two of these to go from the middle of my trailer to my back bumper. I will post pics of my bumper mount when I get my unit from storage yard this weekend.
Camco 57282 10' Propane Quick-Connect Hose by Camco http://www.amazon.com/dp/B00CPYC9BC/..._MGtgtb1EWMKSV
Just glad to get away
Old 03-06-2014, 10:33 PM   #4
I carry an extra propane bottle for my portable stove. I did not want to cook too close to my rig or have a hose for people to trip over.
Anyone can use 3/8 brass coupler fitting and join as many hoses together as they wish. However some jurisdictions have codes that limit the length of flexible hose. Usually it is usually limited to about 3 to 4 feet.
I bought a 10 ft hose today at Lowes for $20. I plan to use it for a ventless heater that currently has two 4 foot hoses joined by a coupler. The flexible hose is necessary to snake around some furniture.
billmac8 is offline   Reply With Quote
Old 03-07-2014, 10:21 AM   #5
Old Enough to Know Better
gasman6674's Avatar
You just need to know if the length/size (ID) of the hose will carry the btu load at ?? pressure
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 03-07-2014, 10:24 AM   #6
Fulltime family RVer
How do you find that out?
Old 03-07-2014, 10:42 AM   #7
Don't mean to thread jack but, this is along the same line. Where can I find an adapter (if one even exists) to go from the quick connect to a gas fryer hose end like you would connect to a 20lb propane bottle?
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 03-07-2014, 10:50 AM   #8
Like this?
Camco 59843 20" Pigtail Propane Hose Connectors - Acme x 1/4" Male NPT by Camco http://www.amazon.com/dp/B007HG7SM8/..._NQEgtb0YG8TKE
Old 03-07-2014, 10:58 AM   #9
gasman6674's Avatar
Doug
Most for the hoses available to the RV/Consumer market will be either 1/4" ID or 3/8" ID
with 3/8 being the most popular. Usually you can look in the end a figure it out. There are charts available to size them one location is HTTP://www.regoproducts.com/lpg/lpg-...iterature.html Select serviceman's handbook L545. or Pm me and if I have time I can check it for you.
Old 03-07-2014, 11:02 AM   #10
gasman6674's Avatar
RickV Most deep fryers/turkey fryers are high pressure and you would need to connect between the cylinder and RV with one of the extenda type tees and use the fryers regulator and hose.
Hope this helps
