Your rig has an auto change over regulator that in the top part takes tank pressure from one tank and 30 psi from the other and reduces it to 10 psi then the lower/bigger section takes the 10 psi down to 11" wc (approx 6.35oz). Ok to answer your question, if you maintain your existing system and feed your bulk tank into your auto regulator I would not recommend going over 20 psi, 10 would be better. If you bypass your rigs regulator, then a common twin stage regulator with the proper sized line from the big tank will do nicely. Hope this helps.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
