Old 12-27-2015, 09:31 PM   #1
HWH pilot issue...
It takes about 5-10 minutes to light the pilot on my hwh. I usually sit there on the chair and hold it. Once it goes on its fine. No issues with other appliances. Fridge is right on top of it, no issues there. Someone suggested a "lazy" thermocouple. Any ideas?
Kuba is offline   Reply With Quote
Old 12-27-2015, 10:17 PM   #2
X2
2011 Traverse LT, 3.6L, FWD
Old 12-30-2015, 05:42 PM   #3
Make sure thermocouple is directly in the flame, clean the soot off the tip of it. If neither of those things work it needs to be replaced.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 01-04-2016, 10:01 PM   #4
Thanks kiddies!
Old 01-04-2016, 10:15 PM   #5
Just to clarify, you say it takes a few minutes to light it.
Do you mean the pilot lights and you have to hold the button to keep it from shutting off the pilot gas? (dirty, maladjusted or a bad thermocouple)
Or the pilot just wont light until you hold the button for a while? (having to purge air from the line before you have propane there to light)
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 01-05-2016, 05:46 AM   #6
Ykdave, are you thinking there is a leak? As i said in my original post, my fridge and stove are within 2-3 feet from the hwh and they work fine on propane?no delay etc.
It takes a while to get the pilot going initially.
