Old 07-14-2014, 10:40 AM   #1
Is it OK to change the way the regulator is facing?
Is there a particular reason the valve is facing the trailer and cannot be facing forward?
I can imagine it is some safety thought, but the hose is so long it is well below the frame rails.
madmaxmutt is offline   Reply With Quote
Old 07-14-2014, 10:50 AM   #2
Triguy's Avatar
Mine face out. I don't see any problem with it.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-14-2014, 10:59 AM   #3
Old Enough to Know Better
gasman6674's Avatar
No Change it to make it more convenient.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 07-15-2014, 07:57 AM   #4
gasman6674's Avatar
Let me expand a little, You can mount the regulator anyway you want EXCEPT vents facing up and spring case (adjustment hole) facing down in the horizontal position. It is also a good practice to protect the regulator from road splash, mud, dirt etc to keep the vents clean. If it can't breathe it will not work.
Hope this helps
regards
Old 07-16-2014, 09:46 PM   #5
Great info, thanks!
Old 07-16-2014, 10:37 PM   #6
Platokidd's Avatar
Im just wondering how far the hose hangs below the frame? That could be a safety concern if it catches on road kill or debris.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 07-17-2014, 12:04 AM   #7
That was my first thought when I saw it. The hose was hanging down about 3-4 inches below the frame. Then I saw the valve/regulator was shoved up against the fiberglass so you can hardly see the indicator. I am turning it around.
