Old 09-05-2012, 09:48 AM   #1
Lacrosse 318BHS Propane Auto Regulator
I just purchased a Lacrosse 318BHS. The camper has a dual propane tank setup with an auto switch over regulator. I ran the passenger side tank dry over the weekend and switched over to the drivers side tank. The regulator still showed red. The tank valve was fully opened so I closed and reopened the valve again and still no gas flow. I disconnected the tank and moved it to the passenger side and the regulator turn green and I got gas flow. It appears the drivers side switch/line is not working. I know the tank is fine because it works on the opposite side so I'm not sure if the problem is the regulator auto switch or gas line. Any ideas?
dfeck is offline   Reply With Quote
Old 10-03-2012, 12:17 PM   #2
Jeffco, MO
tedstr's Avatar
LP Regulator
Good question. I am now having the same problem with my Wildcat 302RL. Will have my dealer check it when I return next week. Will give you his solution if no one on this forum answers.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 10-08-2012, 04:48 AM   #3
Toy-aholic
Very common, happened to me too....mine did it just out of warr. Bad regulator... Fortunately the camp store stocked regulators
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
318bhs
