Larger ASME propane tanks are available but expensive. You could look at what's available and measure your frame to see if the tank brackets will fit on your frame. You may have to drill new holes for the tank brackets. You cannot move brackets on the tank.
Unless you need the propane while driving, a simpler solution would be to get an Extend-a-Stay system, or other brand, and use a grill gas tank.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
