Old 02-06-2016, 10:34 AM   #1
Leak Test
When I do a leak down test on my 21FBRS it passes the standard 3 minute test easily, but after an hour the pressure drops noticeably. Any thoughts? Is it normal? Is it even possible to find a very slow leak like this?
danking49 is offline   Reply With Quote
Old 02-09-2016, 08:23 AM   #2
..and the pressure drops to zero in about 6 hours.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
Old 02-09-2016, 08:47 AM   #3
Not what I consider a leak test IMO. Unless you are running soapy water over the RV while you are searching for leaks, I would consider it a waste of time.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 02-09-2016, 08:52 AM   #4
Yes,what PSI are you using for the test? You should be able to Hear the Leak at 60 PSI,I am talking AIR for the test,NO Clean-Up that way! Youroo!! Also I have never heard of a "Standard 3 Min" leak test!
youroo is online now   Reply With Quote
Old 02-12-2016, 08:10 AM   #5
I'm curious what your trying to achieve. There are so many little things that could be leaking so minutely it may be impossible to stop them all.
Rich5117 is offline   Reply With Quote
Old 02-12-2016, 08:41 AM   #6
I'm just asking if it's always even possible to seal up a system tight enough to pass a standard leak down pressure test (hold 8 in WC pressure down stream of the regulator with zero drop over 3 minutes).
Old 02-12-2016, 08:50 AM   #7
You're wanting to test the LP system?
Mr Havercamp is offline   Reply With Quote
Old 02-12-2016, 05:41 PM   #8
Leak Test
Yes, it should be absolutely possible. I am sorry I misunderstood what you were testing. You should be able to hold 8WCI for no less than 3 minutes. I have not used a gauge when checking our system, I turn on the propane and make sure the regulator goes to a green indicator, then turn off the bottles. Ours has held for weeks. As soon as you turn on something like a stove burner the regulator goes to red. I would feel very uncomfortable if it did not hold pressure. Only once did it leak down, turned out to be a bad o-ring on one of the whips.
You can purchase a flammable gas leak detector at Home Depot, they are very sensitive and will help to pinpoint a small leak at a fitting. Cost is around $25. I carried one in my FF turnout gear used it many times in homes.
Old 02-12-2016, 07:00 PM   #9
Rich5117 Thanks. I thought that auto change valve should hold green for more than a few hours. I'll try that HD gas detector as soon as it warms up a little here in New England! My nose says the leak is probably around the bottle valves, regulator or hoses; all tough to check with soap. Thanks again!
Blue Ox SwayPro 550
Old 02-14-2016, 08:58 PM   #10
Too Tall's Avatar
I'm mix detergent and water in a spray bottle and apply it to every connection I just found and repaired a leak just yesterday in the hose between the bottle and the selector. I lost about a third of the bottle before I realized i had leaks. You can find the tiniest of leaks this way.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
leak
