Old 07-07-2015, 08:32 PM   #41
Windywest's Avatar
I have a solar panel, transfer switch, and a 2000w xantrex inverter. Can run the fridge on ac anytime, including travel.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 07-07-2015, 08:36 PM   #42
Originally Posted by Blackhat6mike View Post
I'm in my 4th TT since the early 1970s and have always run with the frig on propane. It was "designed" to travel while on. Never heard of anyone having a problem from a frig being on except being fined for going through the Mobile AL Tunnel with the frig on.
I worry a great deal more about the cars coming at me at 70 mph and only separated by a paint stripe on the ground.
I say if it makes you feel all fuzzy inside to turn it off, then do so.
You are so right. I agree 100%. Especially the last sentence.
Old 07-08-2015, 07:06 PM   #43
thestrangebrew's Avatar
I turn mine off when traveling. Fridge is on electric a few days before we leave and it stays plenty cold for what we bring. However, the farthest we've traveled so far is only 4 hours. May not be much help, but that's probably the way I'd roll on longer trips as well. :shrug:
Sent from my SAMSUNG-SM-G925A using Tapatalk
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 07-08-2015, 08:29 PM   #44
Timex's Avatar
I like being fuzzy.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 07-08-2015, 08:55 PM   #45
indybp57's Avatar
Of all the things to worry about towing a TT out on the open road a propane fire is probably not going to make my list.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 07-09-2015, 02:40 AM   #46
Crockett's Avatar
there have been some dangerous furnaces over the years. the duotherm 900 and 901 from 1984 to 1988 would mix the lp gas with the air with a blower wheel and then through a ceramic burner head. they used a refractory lining that would still burn up and then burn the bonnet. but a furnace still has a bonnet and the outside casing to protect against the flame. dometic and norcold both have had cores that were failing (leaking)and recalled in the past few years. the flame, even though small, sits within inches of a wooden cabinet. the flue exits within inches as well. the core, when heated, operates at up to 600 pounds of pressure and contains hydrogen gas and anhydrous ammonia. ammonia is flammable in concentrations of 15 to 28 percent in air. the burner chamber (close proximity to flame) is a common area to leak. that is what makes the refer a concern to me. ive done the recalls and seen what parts go in. extra sheet metal around the burner. one or 2 thermal cutoffs to kill the power to the fridge. ive replaced dozens of refer cores over the years. had lots of leakers that didnt catch fire. of course I didnt see the ones that did...
Crockett is offline   Reply With Quote
Old 07-09-2015, 02:42 PM   #47
Crockett's Avatar
Exploding RV Refrigerators Spark A War Among Plaintiff Lawyers
found this. looks interesting. one attorney claims 3 to 5 fires a week...
Old 07-09-2015, 02:59 PM   #48
Timex's Avatar
Thanks Crockett for your insight.
This is one of the most highly debated topics I have seen on FRF and it will go on and on.
To each his own because it is their camper and their life.
And if they feel safe doing it, I won't tell them that they are wrong. It's worked for them for years and they haven't had a problem.
And yes, it could very well catch fire sitting at a campsite.
I'm just not going to do it because it makes me feel fuzzy when I don't.
Old 07-09-2015, 04:53 PM   #49
Crockett's Avatar
almost a million dometic units recalled. industry insider says boiler chamber tubing unchanged, just a external fix. norcold says 80% recall compliance rate "good". I remember the 1200 lrim norcold recall. first they just sent out lower wattage heat elements. then when that didnt fly, a full blown recall on cores. the chimney siren makes more sense now than it did when I first got involved with this thread. some decisions you make for yourself, others affect the entire family. i think Ill spend my lotto money to build one, better odds and potentially higher rewards...
http://www.aegiforensics.com/library...ires-part1.pdf
propane, tank, valve
