Old 06-29-2015, 03:58 PM   #1
Ham Camper's Avatar
Leave propane tank valves open while driving
As a fairly new camper with all the stuff run with electricity or propane I was wondering. While I am driving down the road my fridge is running on propane to stay cool. When I plug into shore power it automatically switches to electricity. Am I correct in this? Or does the 12 volt system provide electricity while driving for the fridge? And I was told that I should leave both propane tanks open while travelling. I am curious to what others do and why. Planning on a long trip this fall and hope I have this all figured out by then.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 06-29-2015, 04:03 PM   #2
Mikegjax's Avatar
I leave my propane on and frig set to automatic while traveling (motorhome). When I hook to shore power it will switch automatically. Some don't and you will hear many opinions on the subject.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-29-2015, 04:05 PM   #3
Ford Idaho's Avatar
When you plug in to shore power it should switch to 120v.
On the move your fridge needs both the propane and 12v to work.
I like to keep one tank closed so I can kind of track how much is used.
Old 06-29-2015, 04:06 PM   #4
Mr. Dan's Avatar
I agree with Mike's every statement (except I have a 5th wheel). This ON/OFF debate runs to several pages about once per month!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-29-2015, 04:06 PM   #5
Ham Camper's Avatar
Well I am pretty sure my TT is set up to do the same thing. Do you leave your propane tank open all the time while you travel then? I think MHs have only one propane tank if I remember correctly.
2015 GMC Denali HD
Old 06-29-2015, 04:09 PM   #6
Ham Camper's Avatar
I kinda figured that this has been discussed many, many times. I always thought that you should keep one closed so when you run out your covered. I guess I will listen to others and come up with a plan
2015 GMC Denali HD
Old 06-29-2015, 04:52 PM   #7
prof_fate's Avatar
Open and fridge running. We leave wed for an 8 hour drive, then several more days of 90F temps and 8 hour drives. I can't see not running the fridge!
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 06-29-2015, 06:27 PM   #8
Oaklevel's Avatar
How you do it is up to you. Just keep your route in mind, many bridges & tunnels require that your propane be off. Many even require that you stop to be inspected to insure that it is off.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-29-2015, 07:06 PM   #9
camping baba's Avatar
I leave one tank open and the other one shut off .it is easer to turn the other tank on when it goes empty than try to find a propane station in the middle of the night .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 06-30-2015, 10:11 AM   #10
prof_fate's Avatar
off or not it doesn't change the flammability of it.
teh issue would be a leak...and at 60mph I doubt it's possible for the gas to collect and explode on a camper.
the fridge and water heater are mostly outside and vented well, furnace? Haven't had to work on that so I don't know, the stove of course is completely inside and I guess a camper COULD fill with gas and blow up.
2011 Grey Wolf 28BH
propane, tank, valve
