Old 03-10-2014, 05:55 PM   #21
NELA
Weezer's Avatar
Also for the same reason we have a security system on our house, and security cameras placed around our property, with a flood light and one camera pointed at our 5er.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 03-10-2014, 05:56 PM   #22
Ford Idaho's Avatar
Guess I need to pick up a few more padlocks and a couple hundred feet of 3/8th chain before we head NE later this year....
Old 03-10-2014, 06:03 PM   #23
NELA
Weezer's Avatar
eDad,
I just checked ours. They have a very heavy duty (steel?) thick band around 'em, with a long bolt and wing nut between the two ends to tighten 'em down.
If ever pressed on the lock issue, FR could just say that hole on yours was for a cotter pin, a backup for the latch/buckle mechanism.
We *could* remove the bolts/wing nuts and put a large padlock through the two ends of our bands I guess.
Old 03-10-2014, 06:47 PM   #24
Cyclone
beipers's Avatar
Not sure I care about the fire scenario because I would run really fast. However, in the event of a leak I'd like to get to the valve before the fire. Sure the keys are on my ring, but those things happen when you least expect. Like the middle of the night, when i can assure you i don't have a pocket.
Sent from my SCH-R530U using Forest River Forums mobile app
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 03-10-2014, 07:05 PM   #25
B47
Good stuff,but will they detect incoming drones?
Old 03-10-2014, 07:17 PM   #26
davel1971's Avatar
no sense risking an insurance company getting out of paying you because you put a lock on the door, but if no regulations about securing tank, that's the way to go.
David & Lynn
Old 03-28-2014, 01:50 AM   #27
Stg1's Avatar
I don't have a door on my tanks, but I still keep them secured with a lock. I drilled a hole through the wing nut and the cross bar holding the tanks in place and purchased a good quality pad lock (Brinks) with a long shank so I could lock mine . In case of a fire I have access to the valves if need be.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 03-28-2014, 05:52 AM   #28
ezawacki's Avatar
I just started to lock my tanks about 2 months ago. No tampering to my unit was ever noticed. Just wanted to keep them secured.
2005 Ford F-250 6.0 Diesel
2013 Sierra 365saq
FLY NAVY
ezawacki is offline   Reply With Quote
Old 04-05-2014, 08:09 PM   #29
Whiteknight's Avatar
That's what I did on our last trailer.
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
Whiteknight is offline   Reply With Quote
Old 04-16-2014, 05:42 PM   #30
Best way to secure propane tanks is to drill a hold thru the large wing nut and another at the same position thru the cross piece that holds the tanks down. then place a good pad lock thru both holes. No need for cables and a good clean install
Brandon 2
2014 T24RG
F-150 5.4
brandon 2 is offline   Reply With Quote
propane
