Old 05-03-2014, 07:49 PM   #1
wowzer's Avatar
LP Flex Line
Situation: Flex line on kitchen slide out gets a kink in it when pulled in not letting the fridge run on LP.
Question: Anybody out there have an idea what I can do(short of buying a new hose) to keep this line from kinking?
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is offline   Reply With Quote
Old 05-03-2014, 08:08 PM   #2
Wowzer an easy fix might be to get a piece of hose bigger than the lp hose, cut it so it fits around the kink then tape with Fusion tape or also known as stretch tape that way there is no sticky tape that will come undone. You should only need about 6 to 10 inches of hose depending on the kink. The tape becomes one piece of rubber after a short time. Hope it helps. Just an easy fast correction. Good luck
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
