Old 10-02-2012, 08:07 PM   #1
Question LP gas line with a quick connect
2013 forest river 5th wheel cardinal came with a LP gas line with a quick connect, I wanted to purchase a gas grill to connect to this quick connect gas line. I need to know what size male fitting to purchase. I don't know what size the quick connect is, I just can't tell by looking at it.
any one else have this set up on their 5th wheel? nothing in the trailer manual to tell me the size
Gee Whiz is offline   Reply With Quote
Old 10-08-2012, 08:57 AM   #2
Quick connect fitting is 1/4"
jacknel is offline   Reply With Quote
Old 10-08-2012, 12:28 PM   #3
Dave_Monica's Avatar
That connection will be regulated, low pressure. If you try to use a grill with it's own regulator, you will not have sufficient gas flow. You'll need a grill without a regulator or one that can be removed.
Dave
Old 10-08-2012, 10:30 PM   #4
Oklahoma Proud
MillerTime's Avatar
We ordered a outside grill for our 2013 puma 295 kbh by palomino. It came with the mount rail already installed next to the outside kitchen (all though it is under the awning). The factory just put the grill box on the master bed.
It is a Outdoors Unlimited Inc.- Side-Kick Grill and I saw another dealers catalogue that had them listed at $160 which is what we payed to add the option.
To answer your question I believe as posted above it is a 1/4" fitting- but a air fitting will not work, looks about the same but the gas line male end has 2 or 3 ribs instead of 1 on air.
I can give you Outdoors Unlimiteds adress or cust. Serv. # if you need or want to ask them any questions. - just happened to have all the books out looking at winterization instructions
Old 10-09-2012, 02:05 PM   #5
OK, thanks for the info.
Happy camping from:
GEE-WHIZ
Old 10-09-2012, 02:06 PM   #6
OK, thanks for the info.,
Happy Camping from:
GEE_WHIZ
