Old 12-02-2014, 12:18 PM   #1
BuckeyeGal
LP Gauge that work???
Anyone have a reliable and accurate means to tell LP level without taking the tank out of the trailer? Have tried the magnetic color coded ones (worthless).
also tried a pressure gauge on my grill few years ago and all it did was decrease pressure grill & interfere with lighting; do NOT want that on my 5th wheel.
thanks.
tvc
Terry & Carol
2012 Sabre 31-CKTS-6
2003 F-250CC 7.3L Powerstroke
buckeyegal is offline   Reply With Quote
Old 12-02-2014, 02:30 PM   #2
Old Enough to Know Better
gasman6674's Avatar
There is an actual float gauge and valve that can be retrofitted to your existing 20 or 30# bottles, or you can buy new tanks with gauges in them.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 12-02-2014, 05:20 PM   #3
arpipeliner's Avatar
There are fiberglass or composite tanks for propane that you can see how much is in the bottle.
Don't know if they are in 30#. I saw one in a 20#. As u moved the bottle you could see the gas move in the cyclinder. Sure they are not cheap.
arpipeliner is offline   Reply With Quote
Old 12-02-2014, 05:24 PM   #4
I purchased an LP gauge at walmart in the BBq section. Its a pressure gauge that you screw into the bottle and then attach the gas line. Its not perfect, but its close. At least you will have some ideas how low your getting.
Richard6959 is offline   Reply With Quote
Old 12-02-2014, 06:21 PM   #5
KDHfan's Avatar
I think the best method is to run one tank at a time. When you run out, manually switch to the other tank and replace your empty. Yep... You might run out in the middle of a shower or night... But a simple change-over is way faster than a trip to town.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 12-02-2014, 07:56 PM   #6
Bryce's Avatar
Pouring hot water down the side of the tank and feeling where the water turns from hot to cold always works for me.
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 12-03-2014, 11:47 AM   #7
I use a luggage scale - weight doesn't lie - You can buy one on Amazon for about $15 (Walmart also has them).
cadman99 is offline   Reply With Quote
Old 12-03-2014, 12:46 PM   #8
buffalohunter's Avatar
Propane Tank Level Check
I recently saw a new way to check the propane tanks. You might be interested in it. I am thinking about one for myself. It is a "Fill level indicator Truma LevelCheck"
Here is the link: levelcheck.com
I wouldn't mind hearing feedback from anyone that has one.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 12-03-2014, 01:38 PM   #9
Helmsey's Avatar
I use the infrared temp gun we travel with and can tell levels of the tanks with it. There is a good temperature change on the bottle where it has propane and where it doesn't.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 12-03-2014, 02:06 PM   #10
I bought one of these on Amazon. I seems to work fairly well at determining the liquid level in the tank.
Amazon.com : Red GasCheck Propane Tank Liquid Level Indicator : Home Outdoor Heater Accessories : Patio, Lawn & Garden
Windjammin is offline   Reply With Quote
