stupid question here, but I don't know much about propane. I had to change a hose from my tank to the regulator. Do you use any kind of thread sealer for the fitting from the hose to regulator?
normally they recommend a liquid paste specifically for propane connection .but thread tape will work . also spray soapy water over fittings when done to check for leaks .
I use Teflon tape, but they also use a lock tight paste in AC work at fittings, and that is a whole lot more pressure the your propane builds up , I'm talking 350psi and no leaks.
If you use teflon tape, make sure you DO NOT get any over the end of the fitting, just on the threads. A small piece of teflon tape in the gas flow can cause trouble!
I have never in 30 years used teflon or any other thread sealer on propane tank connectors, never had any issues. The fittings on the newer style tank with the larger threads seal very tight without anything added.
Obviously on a pipe fitting in a permanent pipe connection I would use something there.
He is referring to the hose to the regulator, this would require some type of sealant. I would use the pipe dope for gas connections.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
