Old 08-12-2018, 07:19 PM   #1
Cyber Phrenologist
Radio's Avatar
LP line from tank to regulator blows apart
Fridge had the "lack of gas" LED lit and I wanted to trouble shoot the problem.
Found this gas line from the tank to the regulator blown apart. Original equipment, about 10 years old. And of course the tank is empty.
Anybody else had this happen?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 08-12-2018, 07:33 PM   #2
KyDan's Avatar
I found a leaky crimp once. It was only a year old. I just cut off the ferrule and put on double hose clamps.
Peace!
Dan & Rita D
Blue Ox WD hitch
2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75
Old 08-12-2018, 07:42 PM   #3
Cyber Phrenologist
Radio's Avatar
Both hoses are 10 years old. I think I'll replace both of them. They're not as flexible and bendy as they should be. At one year I'd do the hose clamp thing.
If your camper is 10 years old you might want to be a little pro-active here.
KU4OJ
Old 08-12-2018, 07:56 PM   #4
llr
Unfortunately don't expect the new ones to last anywhere near that long. I have a 2017 TT and both hoses had leaks either at delivery or within 2 months. I replaced both in the fall and one is leaking again.
Edit, there have been other posts with almost new hoses pulling apart
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 08-12-2018, 08:19 PM   #5
Crusadernoob's Avatar
Don't the tanks have a valve that closes when a large volume of gas escapes?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36
Crusadernoob is offline   Reply With Quote
Old 08-12-2018, 08:39 PM   #6
Cyber Phrenologist
Radio's Avatar
Well, this tank was open and now it's empty. The plastic screw on thing was still attached to the tank. Perhaps it leaked out slowly over time.
KU4OJ
Old 08-12-2018, 08:49 PM   #7
HONDAMAN174's Avatar
The pressure regulator is what shuts down the flow. This was before the regulator. Fortunately those pigtails are 10-20 bucks
Just glad to get away
Old 08-13-2018, 07:51 AM   #8
KyDan's Avatar
Wrong- there is a high flow preventer in each tank but even if it closes there is still a small flow and would empty the tank in a few hours.
I agree it's time for new hoses but hose clamps can get you by for a few days. You'll be amazed at how bendy the new ones are compared to your old ones.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-13-2018, 12:00 PM   #9
Ok- thanks for the correction. I donít like giving false information.
Old 08-13-2018, 07:22 PM   #10
Ham Call N8SAC
Under no conditions would I use hose clamps on high pressure side of the system. Go get new and check them often . Would hate to see you and your family after a fire.
Maxwell D Pratt is offline   Reply With Quote
tank
