Our brochure has this listed as an external feature, see photo. We just bought 2016 FR3 DS32, an wonder if the brochure is for a 2017 model? Do I have one on the 16 model year, if so where located? Thanks
Look underneath your coach if you're looking for an external LP line to hook a barbecue to you should have seen an external line coming off the mainline system underneath the coach, most likely is going to have a quick connect in so you can connect a hose to it into whatever device you're trying to use with LP, if you don't see anything coming out that looks like that then you most likely don't have it
And bingo was his name, lol yeah that's your external LP line, that's going to feed off your main LP system your two front propane tanks or whatever sizes they are, it's a quick connect hose line you're going to need to connect to that external LP and then whatever device you want to use
i have a 2013 rv and can anyone tell me how to add a quick lp connector to my lp tank and run it to the opposite side. is there a kit that I can purchase and if so from where?
Are you wanting this line (to the opposite side) to be at tank pressure (high) or low pressure? (after the regulator)
F&AM Lodge 358 Somerset, PA - JAFFA Shrine - Altoona, PA Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=90
