Old 07-23-2014, 07:12 AM   #11
Originally Posted by Cypressloser View Post
Pssst, and probably a license and ..., it might be illegal where you are or the bulk dealer might remove your tank?
Don't speak out loud what you're thinking, but you're on the right track .
Lol, I did say potentially...
53jimc is offline   Reply With Quote
Old 07-23-2014, 07:17 AM   #12
speedcat's Avatar
I leave my fridge setting on auto. When pluged into shore power it auto switches to electric. I use the gas only setting when I am plugged in and want the fridge to cool faster.Does yours not operate the same way?
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 07-23-2014, 07:43 AM   #13
Originally Posted by 53jimc View Post
Good discussion, thanks everyone.
I'm betting my gas company would not install a wet line, but I'm sure they'd fill my tanks when they come out to fill the big one.
I need to find a suitable place and get them filled now anyway. I didn't realize my fridge was on auto so it ate my gas. Newbie mistake,lol.
I would suspect a leak drained your tank unless you left the fridge on for months. They use very little propane and the burner only comes on for a short time every 2 -3hrs or so if the fridge is not opened.
Old 07-23-2014, 07:49 AM   #14
Yeah, I'm not too familiar with the operation of this fridge... yet. Been traveling a lot, but not in the TT, unfortunately. Definitely need to get up to speed on all this.
Dude I bought it from said it had a tank and a half, but when I checked the other day, both showed empty. Oh well.
Old 07-23-2014, 08:19 AM   #15
Old Enough to Know Better
gasman6674's Avatar
Ok let me chime in here on the safety aspect of gravity filling your bottles from a bigger tank. To fill a trailer bottle or forklift bottle from a bulk tank without a pump you need a "wet line" as stated above. That consists of a Liquid check lock adaptor, a valve and relief valve, hose, hose end valve and necessary connection to connect to tank being filled. (avg retail $250) To fill the tank you must reduce the pressure by opening the bleeder (aka spitter) on the valve. Once pressure is reduced liquid will flow BUT while you are doing this propane vapor is collecting around your ankles and or any low spot (propane is heavier than air) in the vicinity. Since the normal consumer bulk tank is anywhere from 10 feet away to right up against the house(depending on size) this creates a very hazardous environment. Let alone the chance for a freeze burn from splash. Be safe let a professional fill it.
PS It is ILLEAGAL and very unsafe to refill 14oz and 1# DISPOSABLE bottles they are a one time use cylinder. You assume all liability if you do this.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 07-23-2014, 08:26 AM   #16
Good info, thanks.
No, I do not refill the small bottles, never have, don't want that risk.
Old 07-23-2014, 08:28 AM   #17
bend302's Avatar
I agree with OC. Refrigerators use very little gas. I am more suspect of bad info from the seller or a small leak in the tank system.
Also, when I stop at Flying J on my way to Florida for my annual propane refill I also top up my little 5lb grill tank. When they do that they change adapters from what they used on the Motorhome 100lb tank to fill the little one. Just FYI...
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 07-23-2014, 09:20 AM   #18
B and B's Avatar
I would advise unless you are Hank Hill or licences to do so not to fill your own tanks.
This was many city blocks in Toronto after a worker who died transferring propane between two trucks. The place is out of business and lawsuits underway. This change propane filling and storage standards in Ontario. I use Costco for $16- $18 a 30 lb is cheap here in Canada.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 07-23-2014, 09:59 AM   #19
Propane fill
Maybe not caught in the replies, but my neighbor had the Gas Company install a pump on his very large bulk tank that was for the house. I don't know what they charged him, but we both had motorhomes and he would fill mine for practically nothing. This was 20 years ago but can't see why you couldn't go that route.
leland1950 is offline   Reply With Quote
Old 07-23-2014, 10:14 AM   #20
ryand's Avatar
x's 1000 on not refilling the green 1lb tanks. I learned the hard way. Bought the adapter and was doing it fairly regularly until I had one green tank that would not seal and was letting gas escape via the valve at a high rate. I tossed it in the yard until it ran out. Threw out the adapter that day...not worth the risk. More I thought about it the more it has the potential for an explosion of the green tank should they corrode to the point of failure. When metal sheers under pressure...sparks fly and well you know how the rest of the story goes.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
propane
