Old 05-22-2016, 11:03 PM   #1
mud daubers in furnace exhaust
just purchased 03 rockwood freedom 1950 found mud daubers inside of furnace vent not sure how far inside they have gone will I need to remove furnace to clean them out
Steve Royals is offline   Reply With Quote
Old 05-25-2016, 06:03 PM   #2
Are you talking the fresh air vent or the exhaust vent?
If it is the exhaust vent I would remove them the best you can from the outside then fire up the furnace to see if it works properly.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 05-28-2016, 04:40 PM   #3
HarrynSally's Avatar
I had one with mud dauber and I had to remove the whole furnace and clean and painted mine
HarrynSally is offline   Reply With Quote
Old 07-28-2016, 12:40 PM   #4
Had the same problem on another rv I owner. Got real exciting when I fired up the furnace! First thing I do now, with any RV I get is purchase a screen to cover the exhaust vent to prevent critters getting in and making a home.
High Desert is offline   Reply With Quote
Old 07-28-2016, 12:47 PM   #5
northstar1960's Avatar
the fresh air exhaust is one through vent . though it does go through the heat exchanger . i would break out the mud . then use air to try and blow the debris out . you may get lucky
northstar1960 is offline   Reply With Quote
Old 07-28-2016, 12:49 PM   #6
Oakman's Avatar
Yes, as High Desert posted you need to get the screens for the exhaust vent.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
furnace
