Old 05-05-2013, 07:50 PM   #1
mTn_biKer65's Avatar
Mystery propane fitting
Just noticed what appears to be a propane fitting on my frame rail on the front side of my Surveyor Select 235RKS. Can someone confirm this is intended for a BBQ quick connect. If so I'm surprised they wouldn't have finished the job and included the quick connect but maybe that was an option.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 05-05-2013, 08:21 PM   #2
Twisty's Avatar
On ours, the letters "RVQ" are written on the side of the frame right above that fitting.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-05-2013, 08:26 PM   #3
It requires a short nipple, shut off valve, qd fitting, plug and cover. Probably an option.
Old 05-05-2013, 08:53 PM   #4
Fire Instructor's Avatar
They don't plumb it to the quick connect, unless you want the option.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 05-05-2013, 09:10 PM   #5
Phat Phrog Stunt Crew
elind's Avatar
Below is the site where there is the quick connectors for LP line. Be aware that this is a low pressure LP line that has a regulator at the RV tanks. The use of a regulator on the bbq will reduce the pressure too much to the burners.
Hansen, MB Sturgis 250 Low Pressure Quick Connect Plug
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-05-2013, 09:57 PM   #6
That sure seems like an unprofessional way to leave that. On our new trailer, we got a tee with a plug in it about midpoint ahead of the wheels. We had to order the exterior BBQ package just to get the quick connect fitting so we said no thanks.
We wanted a QK fitting at the end of the trailer next to the rear door where the kitchen is. Here is a pic of what I did and a pic of the QK adapter and mods for the hose for our Coleman Roadtrip grill. It took 2 trips to Home Depot, 1 to Ace Hardware, 1 to Home Harware and 1 to a RV parts store to round up all the fittings. Pain in the butt finding all the misc. pieces for some reason.
On the trailer, I used electrical unistrut brackets (Home Depot) and special isolating pipe brackets from a plumbing wholesaler which have plastic insulators to prevent corrosion between disimilar metals (important on gas lines). I used a 10' standard LP hose to extend from the original tee location to the rear of the trailer (affixed with tie-wraps). The QK fitting is now in a nice accesible location.
The Coleman low pressure adapter modification works really well and we get better heat output when 2 burners are running. No more fiddling with the tanks at the front.
Name:	006 (800x593).jpg
ID:	29720   Click image for larger version
Name:	008 (800x443).jpg
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
