Old 10-17-2015, 11:45 AM   #1
hht
Need advice on Regulator replacement. Which one?
I will be needing to replace my propane regulator when I return to my off grid trailer in TX this winter, but I don't know which one to get. I plan on buying at home, then bringing it down with me, as there are no stores nearby where my trailer is set up.
It's a 1997 Forest River Wildwood (5th wheel) with two 30# tanks. The trailer overall I would guess is 36' - 38'in length.
I should have taken part numbers off the regulator before I left last winter, but I didn't.
So, who can tell me which replacement regulator I need to buy?
Thank you!!!!
hht is offline   Reply With Quote
Old 10-17-2015, 11:47 AM   #2
hht
It looks just like this trailer:
1997 Forest River Wildwood 25RKS | D&K RV SALES, Canby, MN
Old 10-17-2015, 11:49 AM   #3
nomad297's Avatar
Where do the tanks reside? Are they right beside each other, or are they on opposite sides of the trailer?
Bruce
nomad297 is online now   Reply With Quote
Old 10-17-2015, 03:00 PM   #4
hht
Bruce, the tanks are right beside each other.
I have found regulators that *look* like they'd work, but I don't know what kind of pressure I should be looking for in a regulator. It's more the technical side of things I'm unsure about.
Thanks.
Old 10-17-2015, 03:14 PM   #5
RV propane regulators all operate at the same pressure, 11 wc inches (approx .4 psi).
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
replacement
