Old 09-26-2014, 06:34 PM   #1
Need Help - Furnace Removal
Does anyone out there know how to remove a furnace from a 2007 Surveyor SV230 ?
The opening under the fridge for the return air vent is not large enough to remove the furnace. Do I have to remove the stove to get access ?
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 09-27-2014, 05:03 AM   #2
arpipeliner's Avatar
Have a different camper. But took down the rear wall in the basement to put insulation. U can see it better but plumbing and ducting on fifth wheel is in the way. Might not be on TT. Wished I knew that when change the module board on hot water heater.
Try u tube. They had several on water heater but I didn't want to take it out.
arpipeliner is offline   Reply With Quote
Old 09-27-2014, 05:38 PM   #3
I previously checked on the net and found nothing, never thought of utube.
Thanks pipliner !
2007 Surveyor SV230
furnace
