04-05-2016, 06:48 AM
Nest or ecobee possible?
I know they require 24v for operation, my question is, do the furnaces we have in our trailers provide LV? Im currently using a digital Honeywell with batteries. 2012 Salem 26 rks here. Not sure of the model number of rhe furnace.
04-05-2016, 08:38 AM
If by 'LV' you mean low voltage, the t-stat has 12volts DC to it. It either gets it from the furnace or the A/C depending on which units you have.
Gotta go campin!
04-05-2016, 12:20 PM
12 or 24v? My ac is on the roof and controlls are built in. T stat only controlls heat.
04-05-2016, 01:36 PM
Hardwired RV stats use 12v.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
04-05-2016, 01:58 PM
I use a Honeywell that needs no voltage from the Furnace or AC unit. Just closes the relay when heat is needed or AC when switched to that mode. Has 3 Double A batteries in it.
B and B
04-05-2016, 02:19 PM
RV's have 12VDC, home units use 24VAC. I don't know of an Ecobee t-stat that uses 12VDC though there may be one.
Gotta go campin!
04-05-2016, 10:11 PM
So, in other words, if using a "home" tstat, we're limmited to ones that have batteries
04-06-2016, 08:50 AM
It's actually more than that. Some have batteries, but they're just for clock backup. You need one that actually uses the batteries to power the functions.
Gotta go campin!
04-06-2016, 10:10 AM
Yes
24v stats use 24 VAC which your trailer does not have.
04-06-2016, 12:32 PM
Thermostat
I wired up a programmable thermostat in my previous TT and it worked great to turn the heat up and back, but as others have said you are working with 12 volts so likely need to keep the dry cells in the unit.
04-06-2016, 01:28 PM
CDR USN Ret
Installation and operating instruction for Suburban SF-42Q (also includes other models), provides wiring diagrams that show the thermostat, furnace module board, and all furnace loads receive their 12VDC power from the external 12V (battery or converter). There is no 12VDC power source within the furnace.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
