Old 04-05-2016, 06:48 AM   #1
Nest or ecobee possible?
I know they require 24v for operation, my question is, do the furnaces we have in our trailers provide LV? Im currently using a digital Honeywell with batteries. 2012 Salem 26 rks here. Not sure of the model number of rhe furnace.
Kuba is offline   Reply With Quote
Old 04-05-2016, 08:38 AM   #2
Head Rambler
If by 'LV' you mean low voltage, the t-stat has 12volts DC to it. It either gets it from the furnace or the A/C depending on which units you have.
Gotta go campin!
Old 04-05-2016, 12:20 PM   #3
12 or 24v? My ac is on the roof and controlls are built in. T stat only controlls heat.
Old 04-05-2016, 01:36 PM   #4
Hardwired RV stats use 12v.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-05-2016, 01:58 PM   #5
B and B's Avatar
I use a Honeywell that needs no voltage from the Furnace or AC unit. Just closes the relay when heat is needed or AC when switched to that mode. Has 3 Double A batteries in it.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-05-2016, 02:19 PM   #6
Head Rambler
RV's have 12VDC, home units use 24VAC. I don't know of an Ecobee t-stat that uses 12VDC though there may be one.
Gotta go campin!
Old 04-05-2016, 10:11 PM   #7
So, in other words, if using a "home" tstat, we're limmited to ones that have batteries
Old 04-06-2016, 08:50 AM   #8
Head Rambler
It's actually more than that. Some have batteries, but they're just for clock backup. You need one that actually uses the batteries to power the functions.
Gotta go campin!
Old 04-06-2016, 10:10 AM   #9
Yes
24v stats use 24 VAC which your trailer does not have.
2007 Surveyor SV230
Old 04-06-2016, 12:32 PM   #10
Thermostat
I wired up a programmable thermostat in my previous TT and it worked great to turn the heat up and back, but as others have said you are working with 12 volts so likely need to keep the dry cells in the unit.
DocRob is offline   Reply With Quote
