Old 02-19-2013, 05:26 PM   #1
rip
rip's Avatar
New Rusty Propane Pipes
What do you guys use, if anything, on the rusty propane pipes on your Forest River trailers? The ones, on my new 2013 Rockwood 2809W I just ordered, may just look bad and not be anything to worry about.
Do you paint them or do they stand up to the rusty conditions under our trailers with any concerns? I haven't found any threads where you talk about how you may do any improvements, or I may have missed them.
ID:	24523   Click image for larger version
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 02-19-2013, 05:54 PM   #2
lindy's Avatar
Nothing but surface oxidation. Trl will fall apart around you before you have an issue with the propane pipes.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 02-19-2013, 07:43 PM   #3
Dave_Monica's Avatar
I painted mine with black tremclad paint for appearance sake only.
Dave
Old 02-19-2013, 07:55 PM   #4
That is black iron and that is what it does, that is nothing compared to what I see in buildings, the older the buildings the worst it is...and FYI the first place you will get a leak is anywhere where there is a fitting because once it is threaded the thickness of the pipe is reduced and this area will break down and leak faster, and all you need to check for leaks is a small amount of soap and water and spray it on the fittings if it bubbles you have a leak.
Old 02-19-2013, 10:03 PM   #5
rip
rip's Avatar
Originally Posted by Dave_Monica View Post
I painted mine with black tremclad paint for appearance sake only. Dave
Thanks, Dave. Did you buy a spray can or brush it on?
Did not know about tremclad, did web search, read a little, located it at Home Depot, sounds like the thing to do for cosmetic appearance.
Ray
Old 02-19-2013, 10:14 PM   #6
I guess the same holds true for the propane tank? My first class C was about 10 years old and the tank completely rusted. I just traded in my 2 year old Sunseeker 2300 and the propane tank already showed signs of rust beginning. Any way to keep the tank looking new and white as when they're new?
KQ2N is offline   Reply With Quote
Old 02-19-2013, 10:19 PM   #7
I just wire brushed the loose scale off and applied the black Tremclad paint with a brush. I've used the same paint for touch-ups on the frame, axles, pinbox and bumper.
Dave
Old 02-19-2013, 10:36 PM   #8
rip
rip's Avatar
I just wire brushed the loose scale off and applied the black Tremclad paint with a brush. I've used the same paint for touch-ups on the frame, axles, pinbox and bumper. Dave
As I crawled around under my new trailer and observed rust already forming here and there, hmmm-m-m-m everywhere, I'm investing in a can of that paint at Home Depot tomorrow.
Someday I may share a story with the forum about a little bit of rust and my boat trailer. It will explain my rust paranoia.
Ray
Old 02-19-2013, 10:39 PM   #9
cstover's Avatar
I am an Officer in Charge of a Coast Guard ship built in 1961. Who wants to share rust stories?
cstover is offline   Reply With Quote
Old 02-19-2013, 11:34 PM   #10
rip
rip's Avatar
Dang, Tremclad only available in Canada. Didn't seem to find same Rustoleum paint product in USA. Figures. Maybe an EPA thing. Grumble.
Ray
