Old 10-17-2013, 03:50 PM   #1
New to using propane on trailers
I just got a 2012 Steath trailer not too long about and was wondering about the propane regulator..
I see the knob spins and it has green/red on the sides (is that saying ones full ones not, or what does it mean?) and do i keep the knob there? or do i spin it?
Im a total noob to this stuff
I also did fill both tanks, but right now both tank values are closed..
thanks!!
Deeks is offline   Reply With Quote
Old 10-17-2013, 03:54 PM   #2
The Green dot tell you which tank is being used; Red dot tank is not in use. The center glass will be Green indicating the tank you are using has gas or Red to indicate the tank is empty.
Turn the knob to change tanks as needed.
Puyallup is offline   Reply With Quote
Old 10-17-2013, 03:58 PM   #3
Fulltime family RVer
I let myself run out TWICE before I figured out that stupid thing:
Learn To RV: Understanding my Automatic Propane Changeover
Old 10-17-2013, 04:04 PM   #4
Operator error, the regulator/control is not a stupid thing, it is a mechanical device and has no intelligence.
Old 10-17-2013, 04:12 PM   #5
KMP44's Avatar
Its an automatic change-over so you don't need to turn the knob to change tanks. It will draw from one, then the other. You just have get used to the way those indicator dots work, so you don't run out. The directions on the tag on mine explain how to reset the indicator after you take off the empty and refill it.
I also found that a little confusing - but the auto switch is really nice feature.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 10-17-2013, 04:14 PM   #6
You know the joke - build something idiot proof and they go and build a better idiot?
I'm the better idiot when it comes to all things mechanical!
Old 10-17-2013, 04:26 PM   #7
I'm right along side of you!
Old 10-17-2013, 06:47 PM   #8
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
The tag attached to the regulator (shown in the picture) describes how the switch works and how it automatically switches over to the full tank when the first one is empty. When you see red you know it's time to get the empty tank filled. Anyhow, read the tag and you should be all informed. Good luck.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-17-2013, 07:21 PM   #9
If you've got a cover on your tanks you might want to consider this mod:
Propane Tank Cover Mod
2011 Traverse LT, 3.6L, FWD
Old 10-18-2013, 12:13 AM   #10
Thanks for all the info guys!
I have a cover on it, but its only the front have, the back end is all open..
propane, trailer
