Hi All,
Kicked the furnace off today and found that I have no airflow from the last vent. It is a 2017 Salem Hemisphere 272. The vent with no airflow is in front of the electric fire place. I know that I should return it to CW for the repair would like to not do that. What are your thoughts?
we had this issue in our sabre with the bedroom vent. It turned out the bathroom vent was pinched and blocked airflow to the bedroom forcing more air out into the bathroom. The dealership went in and straightened it out under warranty. No issues since. I suspect you have something similar going on. Whether it is blocked by something in the duct, blocked by something pinched off, a hole in the duct work or something else get your dealer to check it out while you are still under warranty.
We had the same type of problem in our Windjammer. The front (bedroom) vent had no flow... I didn't discover until after out of warranty-- it was a couple of warm years in Texas. Had the vent repaired when the bottom was opened for mouse damage underneath. The vent hose was kinked closed. That seems to be a problem based on the way travel trailers are manufactured. :/
