Old 04-26-2014, 07:49 AM   #11
Kaadk's Avatar
Originally Posted by cronek28 View Post
I have turn on and off a few times, made it call and not call. The only sound I hear after cycling though the fan, ac, heat. . is a single click that seems to come from the ac 5 second after heat is turned on and and again 5 seconds aafter turned off
Might just need to purge the air from the lines then. Light the stove to be sure you're getting propane from the tank, then cycle the furnace a few more times to see if it lights.
If not, then you might have some kind of blockage.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 04-26-2014, 08:03 AM   #12
You can purchase an electric heater to use for now to save the rest of the trip?
Troubleshoot to see if the thermostat is bad:
Undo the terminals for the two wires connecting the thermostat to the furnace and pull off the wires. Make a note of which wire goes to which terminal. In most thermostats, the wires are held by screw terminals. Unscrew the terminals with your screwdriver. Donít allow the wires to drop into the wall cavity. If there are more than two wires, undo the red and white wires. These are the standard colors for the wires that activate the furnace.
Twist the ends of the wires together.
Turn on the furnace power and watch the furnace. If the burners come on and the blower starts, then the thermostat is defective and must be replaced. If the furnace still doesnít start, the problem is somewhere other than the thermostat.
Gaffer222 is offline   Reply With Quote
Old 04-26-2014, 08:06 AM   #13
iceblaze580's Avatar
Try this if you have the dometic t-stat make sure the fan speed is set to auto not high or low if I have mine set to high or low and want heat my ac will come on at the same time that may be stopping your heat all together
iceblaze580 is offline   Reply With Quote
Old 04-26-2014, 08:24 AM   #14
cronek28's Avatar
I have gas the range works and lights. The fan is on auto I remember them telling me that. T-stat is next on the list . i feel bad the kids are still in good spirit even being cold. "Dad I can see my breath" while eating breakfast. I thought about electric heaters last night but its a 45 min drive to town and Spending $50 on a electric heater after spending 30k on a camper two weeks ago makes me sick
2013 Sabre Silhouette 320FQDS
2010 Puma 26FBSS (TT sold)
2007 2500HD Silverado Classic Crew Cab 6.5 box
"Duramax"
B&W companion slider
cronek28 is offline   Reply With Quote
Old 04-26-2014, 08:34 AM   #15
Electric heater will pay for it self in the long run as you will use the campground electricity instead of your propane.
If thermo troubleshooting does not work call the dealer and see if they can troubleshoot over the phone. They may agree to a mobile tech reimbursement under warrantee. Check with the campground if they have a tech or a # for a mobile tech.
Old 04-26-2014, 08:39 AM   #16
One thing I missed is that you said your ac was making a clicking noise make sure when you are trying to get the furnace to run is make sure when you push the mode or source button on the t-stat it says furnace not heat it may be trying to get heat strips that are not in the ac to turn on that may be why the ac is making a clicking noise
Old 04-26-2014, 09:12 AM   #17
cronek28's Avatar
Jumping red to white doesn't do anything. I still think its weird the ac makes that one click sound. My digital stat only has fan, cool, furnace, on off mode buttons
"Duramax"
Old 04-26-2014, 09:14 AM   #18
Dose it have a fan speed button if so try putting fan speed to auto
Old 04-26-2014, 09:31 AM   #19
Always in heat mode use low speed. And those breakers can look on and be tripped, you probably have tried tripping the furnace on/off. Don't know if your electrical plug in to the furnace could have come loose. Had a pin in my connector not making good contact heating the breaker & tripping. Sorry you are having problems. We always bring the space heaters just in case. Good luck!
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 04-26-2014, 09:35 AM   #20
Here's a link to a youtube video on a Surburban Furnace. You can try shorting across the high temp limit switch to see if that failed? This may not be your model but should be similar. You can google your model # to see if there is any troubleshooting info online.
