Old 04-25-2014, 11:46 PM   #1
cronek28's Avatar
no heat :(
New camper, used heat in the driveway three or four times while putting stuff in. It worked last night while dewinterizing ..... Now I camping with the family, its cold and I got nothing. Its 50 in the camper when I tell the t-stat to call nothing happens no blower no nothing. Unfortunately not a great maiden voyage..... Any ideas????? Thaks
2013 Sabre Silhouette 320FQDS
2010 Puma 26FBSS (TT sold)
2007 2500HD Silverado Classic Crew Cab 6.5 box
"Duramax"
B&W companion slider
cronek28 is offline   Reply With Quote
Old 04-26-2014, 12:05 AM   #2
raspivey's Avatar
That would seem to indicate a 12V problem to the furnace. My best guesses would be a fuse blown or something wrong with the thermostat. I'm assuming that your lights are all working. Try running the temp all the way up and let it set for ten min. or so in case there's a timer on it for some kind of cool down cycle. It MIGHT start up if that's the case.
Old 04-26-2014, 12:10 AM   #3
puff's Avatar
Fuse and or out of propane..?
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 04-26-2014, 12:16 AM   #4
raspivey's Avatar
The blower would still run without propane.
Old 04-26-2014, 12:22 AM   #5
cronek28's Avatar
I have been reading every forum on this I can find. I'm hooked up to shore 30amp power everything else works. No fuse or breacker blown that I can see. I just switch over to other new lp to be save I have as at the range. This suburban has no out side or inside access like the atwoods do all i can see is the heat exchanger
"Duramax"
Old 04-26-2014, 12:30 AM   #6
cronek28's Avatar
T-stat is digital, tried running height .... Nothing. The fan as well ac will run off using that
"Duramax"
Old 04-26-2014, 07:28 AM   #7
cronek28's Avatar
I know this is a pretty generic question and its probably asked once a week . the suburban owners manual had no useful info in it and I'd like to start over on a better note today unfortunately with out a shower since its very cold in here 31 degrees outside, I guess my luck for going out in April but does anyone else have any suggestions? I don't have a mulit tool to test voltage but the camper, the battery are both new and I'm hooked up to power so the 12v should not be a problem right? Any ideas?
Thanks again
"Duramax"
Old 04-26-2014, 07:35 AM   #8
Kaadk's Avatar
Did you turn it off and back on after switching over the LP? If you ran out of fuel it goes into a lockout. Once you switch over you then need to cycle the power to clear the lockout.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 04-26-2014, 07:38 AM   #9
Pull the thermostat off the wall and check if any wires came loose.
Gaffer222 is offline   Reply With Quote
Old 04-26-2014, 07:45 AM   #10
cronek28's Avatar
I have turn on and off a few times, made it call and not call. The only sound I hear after cycling though the fan, ac, heat. . is a single click that seems to come from the ac 5 second after heat is turned on and and again 5 seconds aafter turned off
"Duramax"
