Old 11-24-2015, 11:51 AM   #11
Well here is what we find....heat was working fine in 29 degree weather. Quit after 4/5 hours. Propane turned all the way on, system blows Luke warm inside, outside it is blowing hot air. Stove lights fine. After a few minutes of blowing Luke warm air, system shuts down. Any last thought s?
critt61626 is offline   Reply With Quote
Old 11-25-2015, 07:29 AM   #12
Phat Phrog
RVChick's Avatar
You still under warranty? You may need to have it replaced. That's what happened to us. Now it works like a charm.
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 11-25-2015, 08:59 PM   #13
RVChick, not under warranty as we are the second owners and warranty non-transferable. Exactly what did you have to replace?
Old 11-26-2015, 09:43 PM   #14
MNtraveler's Avatar
No heat
I would suggest to go back over the suggestions already given and try those.
What temp do you have the thermostat set to? And what is the temp in the coach (you find this by turning the thermostat to off and then press + or -. You can then turn the furnace back on.) Just looking for what your temp differential is.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 12-01-2015, 07:49 AM   #15
knockando's Avatar
Same thing happens with ours and I'm guessing the heater unit and all attached parts are fine so I wouldn't worry about that. After working for us (like yours, 4-5 hrs) it shuts off. We think the regulator is freezing up for some reason, maybe moisture in our LP tank. Haven't figured it out yet but did buy an electric ceramic heater that works great down to about 30-35 deg.
knockando is offline   Reply With Quote
Old 12-01-2015, 08:11 AM   #16
A32Deuce's Avatar
If the regulator was freezing up, then the stove would not work or the WH on propane.
A32Deuce is online now   Reply With Quote
Old 12-01-2015, 10:14 AM   #17
2007 WildCat 32QBBS
05CrewDually's Avatar
Critt, did you do the test like I suggested in post 10? I still think your regulator is not flowing enough to support flame in the heater but may be able to support just the stove. You never posted the results so I assume it was never performed.
Again, allow the heater to run while you watch the burner on the stove. If the flame on the stove starts turning yellow and dies down followed by the furnace not putting out heat, I'd suspect a bad or misadjusted regulator. Some have an adjustable setting.
05CrewDually is offline   Reply With Quote
Old 12-01-2015, 10:27 AM   #18
05....we are traveling and it has rained all day and nite for 1000 miles. It hasn't been too cold and got by w an electric heater. We should be home in RI tonight and will try that tomorrow. Thanks for your advise and I will let you know. Appreciate it!
Old 12-01-2015, 10:48 AM   #19
Left Coast
Could also be a tank pig-tail
Old 12-01-2015, 11:29 AM   #20
knockando's Avatar
This is my problem. The stove works fine when the furnace is having issues. I've read the furnace is very picky when it comes to the gas pressure and the stove is just like a gas grill at home. I've purchased and installed a new dual-stage regulator with the same results, sometimes it doesn't work when it gets below ~35 or so.
