Old 11-23-2015, 07:39 AM   #1
No heat
No heat! 2016 Sunseeker, still learning....set thermostat to AU, then furnace. Blows cold air, don't think I hear clicking igniter. On shore power. Worked fine a few weeks ago. Propane 3/4 tank. What are we missing?
critt61626 is offline   Reply With Quote
Old 11-23-2015, 07:51 AM   #2
Phat Phrog
RVChick's Avatar
Are you able to light your stove?
XLR Owners United!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 11-23-2015, 07:56 AM   #3
Future Roo 23IKSS Owner
elundquist's Avatar
No heat
Try closing the valve(s) on the tanks, turn off all gas items, then slowly opening the tank(s) one at a time.
If still nothing then tap the regulator with the handle of a screw driver.
Erik Lundquist
iPhone 6S using Tapatalk
elundquist is offline   Reply With Quote
Old 11-23-2015, 04:57 PM   #4
Yes , the stove lights fine. Furnace blows Luke warm air.
Old 11-23-2015, 05:10 PM   #5
Flybob's Avatar
Go outside and see if any heat is coming from furnace exhaust ( Be careful it is HOT). If so it is working. I does take a while for for heat to come out. So try again only this time let it run for a while.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-23-2015, 05:12 PM   #6
northstar1960's Avatar
How much time are you giving it ? the furnace goes through a purge cycle and it will blow cold for awhile before it tries the ignition cycle , then once lit it takes some time to heat up .
or bad sail switch or bad pc board or flame sensor or ???
northstar1960 is offline   Reply With Quote
Old 11-23-2015, 05:13 PM   #7
2007 WildCat 32QBBS
05CrewDually's Avatar
When it's on blowing Luke warm air, go outside and starting from a distance carefully feel the exhaust air coming out of the furnace. Is it really hot? If so you may have a duct issue. If it's not hot at all then you know there's either no ignition, combustion air flow (sail switch), or fuel (propane) flow. When first turned on you should hear the fan run first. A few seconds later a series of clicks (ignition). The clicking will stop once the fuel is burning. The furnace will give 3 attempts. After 3 tries and it doesn't light it should shut down.
Post results.
05CrewDually is offline   Reply With Quote
Old 11-23-2015, 05:22 PM   #8
The furnace runs for a while then shuts down. I am not hearing any clicking.
Old 11-23-2015, 05:28 PM   #9
It is blowing hot air on the outside. I did hear faint a click a couple of times but it shuts off after a few minutes.
Old 11-24-2015, 03:59 AM   #10
2007 WildCat 32QBBS
If it's blowing hot initially then shuts down you may have a fuel flow issue. Are you sure the tank is full? You could have a regulator going bad.
Try this. Light your stove top burner. You should have a nice blue flame. Now, while the stove top burner is on turn on the furnace and watch the flame on the burner. If it goes real low and/or burns yellow then I'd suspect there is a fuel pressure or flow issue. It may be a simple regulator replacement.
Do you have a switchover regulator and a dual tank setup? Again, make sure the tanks are full.
