When you open the valves on the tanks, you must do it slowly, else the tanks will shut off. Highly unlikely both hoses are stopped up. Other cause could be both tanks are empty. A 20 pound tank, when full will around 44 pounds. A 30 pound tank when full, will weigh around 77 pounds. Use a bathroom, scale, weigh yourself, then weigh yourself holding the tank. Never assume the dealer gave you full tanks, even though they claimed they did. I should have made them way mine.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
