Old 09-03-2014, 03:14 PM   #1
RVPP's Avatar
Noise at propane tanks
When hooking up to head home after four day stay I heard a 'buzzing' sound coming from the propane diverter valve. I turned the tanks off and the noise stopped. Both tanks were nearly full, 2X30 lbs.
Is this a problem and what causes it?
Thanks for your time.
Paul
RVPP is offline   Reply With Quote
Old 09-03-2014, 05:14 PM   #2
H2oski
I can't tell you what the official cause is other than a gas going through a small orfice and you get a vibration. Mine does the same thing.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 09-03-2014, 05:23 PM   #3
MtnGuy's Avatar
I had a noise problem when 1st got my camper. The regulator was replaced with no solution. The RV dealer replaced the pigtails, and all has been good until recently.....those puppies are starting to make noise again.
Old 09-03-2014, 10:24 PM   #4
Canadian Member
itat's Avatar
I had a similar problem but my chirped and squealed.
Try changing the pigtails first. It's the least expensive solution. If only one side is making the noise, switch the pigtails an see if that stops it. If it does you only need to replace the one that's causing the noise.
2010 Rockwood Roo 23SS
2009 Ford F-150 XLT SuperCrew with Max. Towing
10K Equal-i-zer
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 09-03-2014, 10:29 PM   #5
NELA
Weezer's Avatar
We had a horrific sound from the propane tanks on our V-Lite. It was generated by the regulator "diaphragm" so says Sneak. I can only describe it as a chatter/whistle.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
propane, tank
