Old 04-18-2014, 02:36 PM   #1
HONDAMAN174's Avatar
Noise from vents
Alright- just got my unit back from the dealer. I have a ticking noise coming from the duct work in the floor when the furnace is on. Only heard from by the vents in master bed and in front of entertainment center. Ticking is a consistent beat and can be heard after about a minute. Dealer says it is "heat expansion" and nothing can be done.
Any thoughts ? If FR is listening would sure like to remove the annoyance. Bought unit in dec 13
Just glad to get away
Old 04-19-2014, 10:12 AM   #2
Just a refresh to see if anyone has ideas.
Old 04-19-2014, 10:13 AM   #3
TURBS's Avatar
I would have to agree on it being heat expansion.
Old 04-19-2014, 10:35 AM   #4
Would suggest pulling the vent and check to make sure the transition is secured adequately to the floor and use alum tape to seal it. The plastic duct work should not make any noise. You might have a pc of the plastic duct loose in the duct also that is flopping around.
Old 04-19-2014, 11:17 AM   #5
I hear heat expansion pops & creaks from my duct work after the heater shuts off. I don't hear them while it's running but then again, maybe the noise of the heater drowns them out or I'm not paying attention.
Ticking with a consistent beat has to be something else. But it could be something as simple as vibration from the heater causing a wire to tap on your ducting. I bet it's hard to trace.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 04-20-2014, 10:49 AM   #6
Jimmerinwi's Avatar
Sure it's not a bomb? seriously, check for a loose duct.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 04-20-2014, 11:16 AM   #7
The dealer said that they found nothing loose but we all know how hard some people look for random noises.
Old 04-21-2014, 06:32 PM   #8
tmhyer's Avatar
Could it be an igniter trying to light?
Sent from my DROID RAZR using Forest River Forums mobile app
tmhyer is offline   Reply With Quote
Old 04-21-2014, 09:45 PM   #9
Possible. Sounds JUST like an inigtor popping. But it is being hear only on one side of the TT and the furthest vents.
Old 04-21-2014, 10:07 PM   #10
vent
