Old 06-29-2014, 07:10 AM   #1
Pilot light will not remain lit
Hello, 2002 Shamrock. The pilot light on my Suburban water heater suddenly will not stay lit. It will remain Lit for 30 seconds or so but will then go out. There is gas in tanks. Any ideas. Everything else works with the propane. Thanks
ohhimself is offline   Reply With Quote
Old 06-29-2014, 07:51 AM   #2
Herk7769's Avatar
Your water heater is working as advertised. The light is not an "ON" light; it is a "calling for heat" light and a "flame never lit" warning light.
Calling for heat - water cold; light comes on; then fire lights; light goes out.
Calling for heat - water cold; light comes on; NO FIRE; light stays on; water heater tries again (3 times total); Heater fails; light stays on until you reset it by turning OFF water heater.
If your light takes more than 10-15 seconds to go out, your heater is struggling to light. Something could be wrong that is causing unreliable ignition. Bug nests in flue is the usual suspect; though improper air shutter for altitude; dirty nozzle; or bad spark electrode/gap could also cause long "light" times.
Name:	DSI Sequence.JPG
ID:	56632   Click image for larger version
Name:	DSI explained.JPG
HAM CALLSIGN - KC3FFW
Old 06-29-2014, 08:05 AM   #3
fonzie's Avatar
He might actually have a "pilot light" in the heater as it is a 2002 model....might not be DSI?
Fonzie
Old 06-29-2014, 08:09 AM   #4
Thanks for the reply but mine is your basic need to go out and hand start with lighter. No ignition model. It seems to stay on for a brief period then go out. : (
Old 06-29-2014, 08:17 AM   #5
Get your wh manual out and check for the dimensions of the thermocouple. It might not be properly located or defective.
Old 06-29-2014, 08:18 AM   #6
Herk7769's Avatar
SO sorry!
Several things can cause this.
Low propane pressure - Out of/low propane or the tank valve pigtail safety may be closed or partially closed. Turn off the propane; wait 3 minutes; CRACK the valve and SLOWLY open it allowing the lines to fill. Light your range burners till they light and the flames are blue and stand tall on high.
Water heater Regulator
Reignitor module (if equipped) or control panel issue (depending on model).
Name:	reignitor module.JPG
ID:	56641   Click image for larger version
Name:	Reignitor module for Gas Only Water Heaters.JPG
ID:	56642   Click image for larger version
File Type: pdf Suburban_Water_Heater_Service_Manual.pdf (3.60 MB, 34 views)
Old 06-29-2014, 08:22 AM   #7
Mine is the last picture. Thanks. I will try your suggestions and let you know.
light
