Old 07-25-2016, 11:37 AM   #1
jim
Propane bleeding off
I have a fairly new camper and last year when I was done camping I would shut tanks off each weekend and turn back in following week and the green would still be in the regulator. Now this year after I shut off propane tank it seems too bleed off or go somewhere cause every time I turn tanks back on I have air in system. Is this normal
candace123 is offline   Reply With Quote
Old 07-25-2016, 11:46 AM   #2
Georgia Frog Rally 2017
aceinspp's Avatar
Yes over time the system will bleed off if not used regularly. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 07-25-2016, 02:42 PM   #3
Old Enough to Know Better
gasman6674's Avatar
You have a leak.
Pressure it back up and soap test, (dish soap and water) all of the connections you can see/reach and watch for bubbles to grow. Or call your local LP dealer and see if they can do it for you. Could be a loose connection, could be a leaky hose or pigtail.
Good Luck
PS the green shows if there is more than 10 psi between the tank and the regulator, less than 10 and the regulator will switch to the reserve tank.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
propane
