Old 04-27-2014, 03:43 PM   #1
Propane bottle noise
I'm having an issue with one of my propane bottles that hopefully someone can help me with. Whenever the furnace or water heater is on it makes a loud pinging noise. Only one bottle does this. Of course the dealer couldn't duplicate it when I took it on for some other work. I was in a hurry and didn't have time to wait when I picked it up. I recorded a video of the sound.
1398629669.mp4 Video by tonyswank1 | Photobucket
2016 Heritage Glen 276RLIS
2017 RAM 3500 DRW 4X4 6.7 Cummins
tone100 is offline   Reply With Quote
Old 04-27-2014, 09:25 PM   #2
rsibarra2010's Avatar
Mine does the same thing whenever the furnace or water heater is on. I just assumed it was the propane going through the check valves and regulators. Hopefully it's nothing to worry about.
rsibarra2010 is offline   Reply With Quote
Old 04-27-2014, 09:29 PM   #3
dcheatwood's Avatar
Wow. When you say makes a noise, you mean it. I've never heard that before. Sounds like a pendulum swinging around in there. Ha. Hope you figure it out. Maybe shut down all flow and restart.
Or switch bottle left and right to see if its the bottle causing it or the connection . Just guesses.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-27-2014, 10:01 PM   #4
Evereddie's Avatar
I have something similar but quieter and on both tanks. Hmm?
Evereddie is online now   Reply With Quote
Old 04-27-2014, 10:16 PM   #5
Canadian Member
itat's Avatar
I had a similar problem. Replacing the pigtails solved it.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-27-2014, 10:28 PM   #6
I might try changing the pigtails. That would be an easy thing to try. It only happens on one bottle.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
Old 04-27-2014, 10:30 PM   #7
Canadian Member
itat's Avatar
You could try dcheatwood's suggestion first and switch the chirping pigtail to the other bottle to verify that it is the pigtail. In my case, both sides were making the noise.
Old 04-27-2014, 10:36 PM   #8
onetonford's Avatar
It could be the float on the opd valve is broken and is trying to shut off flow during use. The float is for when you fill tank it will not over fill past 90 percent I would take it to a propane dealer and have it checked out to make sure that it can't be over filled because if you get liquid in your pipes it can be dangerous.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 04-28-2014, 06:27 AM   #9
Canadian Member
itat's Avatar
In my case, I replaced both tanks first and still had the noise, so I got advice here to replace the pigtails. Replacing a pigtail is much less expensive than replacing the tank. I would do that if a new pigtail doesn't fix it.
Old 04-28-2014, 06:31 AM   #10
fonzie's Avatar
Take the propane bottle that makes the noise out and hook up it up to your propane BBQ (if you have one) and see if it still makes the same noise. If not, then most likely it is the pigtail.
Fonzie
propane
