Old 08-16-2015, 01:00 PM   #1
Propane campfire hookup
We were given a portable propane fire pit by a friend who had two of them. He used a 5 lb tank to run it. We have a 5th wheel with a quick connect for the side mounted grill and would like to know if there is an adapter we can use to connect this fire pit to the quick connect. The fire pit has a standard hose with a propane tank connector.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 08-16-2015, 01:24 PM   #2
Phat Phrog Stunt Crew
elind's Avatar
I you go to a RV dealer you can get a quick connector for the low pressure RV connection. The trick to the system is that the pressure regulator needs to be removed. That's because the RV quick connect already has the pressure reduced at the RV tanks before the connection. Or you can get a T at the 20-30 lb tank and run a hose off that, You can buy a ready made set up.
2014 Wildcat 327ck
elind is online now   Reply With Quote
propane
