Old 02-18-2012, 10:09 PM   #1
Propane detector
My popane detector keeps going alarming. I have no gas turned on anywhere. I finally had to disconnect it. Is it common for them to start acting up.
ndtiger is offline   Reply With Quote
Old 02-18-2012, 11:07 PM   #2
They start acting up when your battery gets low. They give a a beep every few seconds. if you have a constant alarm, then have a gas setting it off. Might be propane, might be hairspray, might be anything from an aerosol can. If constant, it has detected a gas it doesn't like. I it just is steadily beeping, probably low 12 volt battery.
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-18-2012, 11:10 PM   #3
TURBS's Avatar
I second windrider
Old 02-19-2012, 05:41 PM   #4
kevinC's Avatar
Yep, ours does the same when the battery voltage gets very low.
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
Old 02-19-2012, 05:52 PM   #5
Moderators' Assistant
bikendan's Avatar
as the others have said, your 12v battery is the most common cause, if you don't install a battery disconnect switch or take the battery out or don't keep the shore cord plugged in.
the propane detector is just one of the many parasitic power drains that RVs have.
a bad detector is a much rarer cause, but it does happen.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 02-19-2012, 07:27 PM   #6
Send a message via AIM to jk31668
they will also begin to act up when they get to be 3-5 years old. somewhere on the unit there is a date to guide you. the radio active material inside wears out and you have to replace the whole unit.
jk31668 is online now   Reply With Quote
Old 02-20-2012, 12:35 PM   #7
well I stay hooked to shore power at all times. The detector is only 18 months old.
I hooked it back up yesterday and as of now its not doing it anymore
